FreeEnergy
User 'hartiberlin1' has exceeded the 'max_questions' resource (current value: 90000)  >:(
allcanadian
I was thinking of that as well supersam, our wise friends talking about generators and computers really have no idea about engineering efficient mechanical systems. So you use a one-way bearing in the fulcrum and use springs on the hammer side to limit movement. Then you attach a flywheel to the one-way bearing shaft, when the pendulum hits the top of its swing on one side it hits the flywheel and momentum is transfered from the flywheel to the pendulum. If it works for more than 5 minutes you have your proof. Absolute simplicity in design and function comes from knowledge and understanding- not textbooks.
arbus
I tried this experiment.  You should try it too!
It is really easy to see that if you reverse it, ie oscilate the lever then the pendulum will gain momentum.
Please prove me wrong... :)
And no. the woman will not save 12 times the energy or sweat. She has to put just as much force on the pendulum as she would on the pump (more actually).  It is just a lever action.  Same when he is pushing the pendulum with the torch.  Remember the stationary torches are not moving.  The one in his hand is.
And Yes the pendulum loses momentum when the lever oscilates.
Think about it... pendulum swings out, lever goes down.  Pendulum has lost energy. In the small demo video it dosent appear to lose energy because the Springiness in the lever stores the energy.
Again, Try it!!!
What is the first thing you would do if you really were generating 12 times more energy?
arbus
Please if there is something i am not getting here let me know...
But i believe the mystical resonance effect is better thought of as stored energy.
hartiberlin
@Arbus,
please post a few pictures yof your experiments,
so we can see, if you did the setup right ?
Many thanks in advance.
