0 Members and 25 Guests are viewing this topic.
ltseung888
Quote from: TinselKoala on October 17, 2014, 06:20:16 AM
No, they don't. No, it doesn't.
Please feel free to cite some scientific references for the _obtaining_ of energy from the "zero point".
Please study my posts starting from reply 2179.
ltseung888
Engineers' meeting on Oct 19, 2014 at Peter Chan's Office.
The Chan Wheel was pivoted on two loose screws.  That was not ideal but was sufficient for learning and getting data purposes.  Top picture showed Mr. Peter Chan and his wheel with Weight W1 hanging and resting on files as support.  Bottom picture showed Weight W1 moved to lever arm.  A crank will be used to convert the up and down motion to rotational motion.
Comments include:
1. Use a larger wheel.
2. Use trianglar frame to provide flexibility.
3, Firmer construction to reduce shaking.
4. Use a proper shaft for Lever to reduce friction.
5. Look for ready-made crankshaft.
The consensus was that it is worth the trouble to do the Loopback.  It may take longer than a few days.
The PDF file was used effectively.  It explained why the Ting Wheel should have an unbalanced wheel.  The setup would not slide any more.  Simple but effective set up for discussion amongst engineers.
Follow the Divine Hand.
ltseung888
 http://youtu.be/p4rgLBU34Oo
Chan Wheel first part is available for viewing at youtube.
The main purpose of the first part is that the unbalanced wheel is "equivalent" to the pendulum.  The weights and lever arm positions are adjusted to provide the largest "lead-out" gravitational energy.
Note that one pull can rotate the unbalanced wheel over 10 times.  The screw pivot had a large friction.  There was considerable shaking.  Such losses were high.  The "hand feel" by the Engineers indicated that the up and down forces on Weight 1 (2.5 Kg) was considerable.  After improvements, the feedback mechanism with crankshaft and chains will be added.  Your suggestions are welcome.
ltseung888
Comments from Aaron Quant:
1.  We now understand that the "pulsing" or "jerking" motion is responsible for leading out gravitational energy.  The use of an unbalanced flywheel is essential.
2.  In all Universities or Technical Institutions, unbalanced rotation is automatically considered as "bad engineering".  No wonder the traditional scientists and engineers missed the Lee-Tseung lead-out energy theory.  Many automatically rejected it.
3.  It may be possible to use almost any low power engine to drive an unbalanced wheel to lead-out gravitational (and electron cloud) energy.  Use the chain mechanism to drive a larger generator.  The larger generator may be able to generate electricity to drive electrical appliance and also drive the low power engine.  Once started, such a lead-out energy system can run forever.
4.  If the Ting Wheel can generate 5KW and the battery can be fully recharged, the World will have a useful product "right away".
5.  The Military in USA, China and elsewhere can no longer keep the secret.  The 225 HP Pulse Motor is not a hoax.  Will the Military (and the Oil Interest) kill all the scientists and engineers who read the Tseung posts?
My advice to Tseung is to continue to follow the Divine Guidance and benefit the World.
ingyenenergiagep
U should use 2 rigid and strong metal weight holder like pendulum weight holder. It takes less air resistance loss.
The xtra energy comes from centrifugal force. Make resonace in system.
