0 Members and 68 Guests are viewing this topic.
ltseung888
Suggestion from a mechanical engineers who now owns a chain of fast food restaurants.
You should check on some Office Toys that has elements of pendulum, seesaw and rotation.  With a gentle push, they can rotate for a long time.  You may be able to enhance them with magnets placed in the right places.
You can save money and time.  May be the toy manufacturer will improve their toys with your enhancement and let such toys lead out energy and rotate forever.  Such toys cost only a few US dollars.  Many are made in China.
http://www.officeplayground.com/Surfer-Balance-Mobile-P1456.aspx
I am more interested in the Tong or Ting Wheels that can deliver real electrical power for the home.  I saw the WITTS 40KW generator video before but I did not believe it.  Now I am not so sure...
ltseung888
Completing the Lee-Tseung Lead out Energy Theory.
The two attached slides say it all.
The Theory is now complete.  Let the Engineers take over.  Let them shine and benefit the World.  Amen.
ltseung888
While waiting for the Engineers to build the frame and re-engineer the axles etc, we discussed the possible addition of the seesaw element to the Yuen Wheel.
1.  Do not do it unless absolutely necessary.
2. An Unbalanced Wheel Rotation is like a person jumping up and down on a scale.  The reading on the scale will sometimes be higher and sometimes lower than the actual weight of the person.
3. The two Unbalanced Wheels of the Yuen Wheel will provide the seesaw action because of the placing of the Weights.  One Weight on each Wheel may be sufficient.
4. If the Milkovic 2SO can lead out gravitational energy via the combination of the swinging and seesaw action, the modified Yuen Wheel must be able to.
5. The Engineering is likely to be less than that of the Chan Wheel.
6. The Officeplayground.com serfer toy may indeed lead out gravitational energy.  That may explain that even with all the movement, a gentle push can cause very long period of movement.
Merg
New paper by Jovan Marjanovic
Dry Friction and the Milkovic Effect
The goal of this paper is to exclude dry friction as a cause of the increased duration of oscillation of a pendulum when compared to the rotation of a wheel, starting after the initiation of their movement and waiting until the movement is stopped by itself. Since this phenomenon was discovered by Veljko Milkovic, an inventor and a member of the academy of inventors of Serbia (SAIN), the author has chosen to name it the Milkovic Effect. The opinion of the author is that this phenomenon is complementary to the Aspden Effect, which will be further discussed in this paper, along with other inertial anomalies known to the author.
http://www.veljkomilkovic.com/Docs/Jovan_Marjanovic_Dry_Friction_and_the_Milkovic_Effect.pdf
ltseung888
First test results with the new frame and new bearings for the Yuen Wheel.
The most surprising result with the supposed better engineered Yuen Wheel is that the result was much worse.  For free rotation with no weights, the number of rotations dropped from 30 to 7.  For the best result with 6 weights, the number of rotations dropped from 150 to 40.
The probable cause is the large bearing producing much higher friction.  Shall buy new small bearings to repeat experiment.  Choice of parts is important.
Youtube video showed that the number of rotations with 6 weights decreased.  The son of Mr. Peter Chan was the helper.
http://youtu.be/H714X0fJxKk
