0 Members and 74 Guests are viewing this topic.
ltseung888
         Explaining the workings of the QEG from the point of view of the LEE-TSEUNG lead out energy theory.
1.  The QEG has a Tank Circuit or a LCR circuit.  L is provided by the large Coil.  C is provided by the large number of capacitors.  R is provided by the resistance of the Coil and other elements in the circuit.
2.  Such a Tank Circuit can produce resonance at a given frequency.  The QEG is designed to have resonance at 400 Hertz.  Resonance shows itself as an increase in amplitude of Voltage (and/or Current). Such a frequency at 400 Hertz will produce audible sound.  This makes tuning much easier.
3.  At resonance, Energy from the Environment can be lead out or brought in.  In the First Divine Revelation of the LEE-TSEUNG theory, sound resonance can bring in the kinetic energy of air molecules.  In the Second Divine Revelation, a horizontally pulsed pendulum can bring in gravitational energy.  In the Third Divine Revelation, magnetic or electromagnetic energy can be brought in similar to a pulsed pendulum.
4.  In the latest Divine Revelation, the lead out energy in the last case is the Electron Cloud Energy.  Chemical Energy comes from Electron Cloud Energy.  Different Compounds of same elements contain different Electron Cloud Energies.  Chemical reactions change the Electron Clouds of the Compounds and thus releases chemical energy.  We can now release such Electron Cloud Energies without chemical reactions.  There is no violation of the Law of Conservation of Energy if we use such Electron Cloud Energy.
5.  The QEG brings in the Electron Cloud Energy via an Excitation circuit (Spark gap and capcitor) and the rotation of the axle.  The rotational speed of the axle can be changed by an external motor.  There is nothing magic about changing the rotational speed.  It is standard electrical engineering.  Once the rotational speed matches the resonance frequency, large amount of lead out electron cloud energy enters the system.  Such a situation is demonstrated by a large increase in brightness of the light bulbs.
6.  The amount of lead out electron cloud energy is likely to be governed by the excitation sources.  These include the amplitude of the excitation (size of the spark gap, voltage, current and value of the capacitor), the construction of the rotating shaft (shape, material and construction), the Coil Winding, the secondary coils, and may be some unidentified elements.
7.  Resonance can be maintained by rotating at the correct speed.  The lead out energy can last at resonance forever.  It is a matter of bringing such energy out to be used by ordinary electrical appliances.  The WITTS device claimed to generate 40KW.  The 225 HP Pulse Motor can generate over 150KW.  I believe it is a matter of tuning the components mentioned in point 6.
8.  It may even be possible or better to excite the tank circuit with a separate DC circuit as in most pulse motors.  The amplitude of the Pulse Current can then be increased easily.
9.  With sufficient lead out electron cloud energy, we can power electrical appliances and do self loop (and recharge any battery if needed).
The most important element in all the discussion is that at resonance, we can lead out the Electron Cloud Energy.  This amount of lead out energy is not dependent on the Input energy of the rotating motor.  In fact, the rotational speed does not need to decrease at resonance!  Many engineers did not hear a reduction in motor speed at resonance and concluded that the WITTS device was a hoax.  They need to re-learn.
I shall be working with the China and Taiwan QEG Groups.  The chance of our success is high because we have the LEE-TSEUNG lead out energy theory to guide the development.
God Bless.
Void
Hi Lawrence. This video was posted recently to overunity.com.
I believe it uses a rocking lever with fixed magnets to cause a flywheel with fixed magnets to spin by magnetic interaction.
Thought you might be interested. It is not self running, but the guy is looking for suggestions to improve his device...
http://www.youtube.com/watch?&v=UetZl09h5ng
By the way, the WITTS people appear quite shady, reportedly charging people lots of
money for plans and 'training' which still does not provide people with enough information to build
a working self running device. Very questionable people. I am personally not aware of anyone who built a device
from WITTS that actually self runs. For example the QEG folks do not have a self running device although they apparently
already paid a lot of money to WITTS for plans and training. In my own opinion, it is not a good idea at all to associate serious
research with anything to do with WITTS. Just my own opinion.
All the best...
ltseung888
I always use DC to get resonance in tank circuits.  In the QEG set up, the exciter circuit apparently uses AC.  Am I mistaken?
With AC, there is always pulsing in the opposite direction.  If this is not perfectly in sync, it is like someone pushing the swing back at you before the maximum amplitude is achieved.  The swing may still move but not at its highest efficiency.  Line AC is at 50 or 60 hertz - not 400 as designed.
QEG founder James already stated that the plan he got from WITTS were not complete.  He had to modify and innovate.  May be the lack of sufficient output to provide loopback is due to using AC instead of DC?
We changed the pendulum to unbalanced wheel on the Milkovic 2SO with excellent results.  Can changing AC to DC work similar miracles with QEG?
Paul-R
Quote from: ltseung888 on November 15, 2014, 07:55:38 PM
Don't forget that the essence of a tank circuit (and its resonance) is that it must be driven by an oscillating power source.
ltseung888
Quote from: Paul-R on November 16, 2014, 10:35:47 AM
The spark gap already provides the oscillating source, we do not need mains AC to vibrate at the wrong frequency.
