ltseung888
Quote from: TinselKoala on December 14, 2014, 04:30:48 AM
Not many, and the only ones who do, are wrong. There is nothing OU about those systems and you are wrong too, Lawrence. If the system is not powered, the amplitude of the swing will decrease as your external weight is lifted over and over. If the system is powered, the input power may replace the losses on a 1 to 1 basis. You have no coherent measurements to support your contentions. Any pendulum, single double or chaotic, is only a flywheel in a different configuration, converting potential energy of position to kinetic energy of motion.
TK
Let us focus on the Milkovic 2SO.  Please re-examine the video.  Compare the work done by the finger push and the lifting of the Weight twice.  The overunity or lead-out of gravitational energy occurs at this point.
I now have the Chan Wheel to do accurate scientific experiments.  Some repair work needs to be done.
The plan is to produce a few Chan WHeels and send them to the local Universities in Hong Kong to do accurate measurements.
Please check the mathematics and Physics of the horizontally pushed pendulum.  Please point out what is wrong.
Paul-R
Quote from: ltseung888 on December 14, 2014, 07:15:13 AM
You have to be very careful that, as the weight descends, it is not putting back into the system the energy that is used to lift it, resulting in no net overall gain.
I think the Ting wheel is far more interesting because it deals with electrical issues which make OU more explainable (quantum foam, charged particles jumping into existence and gone again etc etc).
noonespecial
I always thought that the two stage oscillator was suspiciously similar to a common balance scale... :)
ltseung888
Quote from: Paul-R on December 14, 2014, 09:14:46 AM
@Paul-R,
Thanks for the advice.  Our job is easier because we shall give away Chan Wheels to Universities to do more research and measurements.  I learned from my mistake - an old man with bad eyesight, bad hearing and weak bones MUST not do experiments involving lifting of many Kg weights.
We shall focus on the comparison of INPUT at the finger push stage and the OUTPUT of lifting the Weight twice.  That can be a continuous process.  Effectively, we want to confirm the attached theoretical concept.
ltseung888
Quote from: noonespecial on December 14, 2014, 09:57:55 AM
@noonespecial,
If you keep jumping up and down on the scale, you will simulate the Milkovic 2SO better.  The pendulum moment is not constant.  It is the sum of the weight of the pendulum bob plus the centrifugal force.  The centrifugal force is highest when the velocity is highest (when the bob is at lowest position).
The "jumping" is the magic that leads-out or brings-in gravitational energy.
See the Chan Wheel videos again...
