ltseung888
Quote from: tagor on December 18, 2014, 12:00:18 PM
you put your device a litle above the resonance
then you put a load ...
if it is slowing => you get resonance ... and more output ( with what you think ! )
now did it stops ?
Thank you tagor.
You probably explained why the Chan Wheel showed a much higher lifting of the weight in the third, forth, fifth or sixth rotations sometimes.  The Chan Wheel was repaired.  There was no more sliding of the pivot.  The surprising result of much higher lifting of the weight stated above was repeated and reproduced every time (6 times).  COP was clearly much greater than 6.32.  The ruler set up was not able to measure the height lifted but the value was definitely greater than 10cm compared with 4.6cm in previous measurements.
Thus 12 times more output was confirmed from such experiments.
Christmas present is now ready.  Blessed be the Almighty.
http://youtu.be/uU0WFJ6ezLc
The comparison with the balanced Chan Wheel that will not lift weight is shown here.
http://youtu.be/qHrDL3d4Wt8
We shall arrange for third party engineers to validate the results and then send two Chan Wheels to local Hong Kong Universities for more scientific and accurate measurements.
ltseung888
The new question is:
1.  To maintain the rotation of a balanced wheel, the energy required is to overcome friction.  The weight of the wheel is not an important factor.
2.  What is the energy required to maintain the rotation of an unbalanced Wheel?
3.  If the unbalanced does not do a full rotation, it will swing backwards and forwards like a pendulum.  The energy required will be similar to that of a pendulum.
4.  If a pulsd pendulum can lead out gravitational energy, can an unbalanced wheel with initial excess potential energy lead out gravitational energy?
5.  Will that explain why the Weight can be lifted to greater height at the 3rd to 6th rotations sometimes?
6.  There can be vigorous mathematics for the pulsed pendulum.  Can there be similar mathematics to determine the actual energy lead-out or bring-in for the Milkovic 2SO or the Chan Wheel?
tagor
Quote from: ltseung888 on December 19, 2014, 02:50:10 PM
with this miraculous COP ...
I am waiting :
1) transformed weith-lift into heat
2) transformed heat into electricity
3) transformed electricity into mecanical work
4) and bingo , loop the device !
ltseung888
Quote from: tagor on December 20, 2014, 02:59:13 AM
I am waiting :
1) transformed weight-lift into heat
Dear Tagor,
The much easier strategy is:
  1. Get third party engineers to confirm the results at Mr. Peter Chan's Office.
Help them to build their own Chan Wheels.  Have two or more local universities to do more   vigorous scientific measurements.
  2. Once the Lead-out Theory is confirmed beyond any shadow of doubt, heavily promote it.
  3. Other experiments will be done by multiple parties simultaneously.
·        Convert up and down motion into circular motion to do loopback.
·        Convert up and down motion into electricity by moving iron rod in coil.
·        Put Unbalanced Wheel in horizontal position and simulate a horizontal pendulum.  Use magnetic fields instead of gravitational field to lead out energy.
·        Change the simple Unbalanced Wheel to a Pulse Wheel with magnets and electromagnets.
·        Use two Unbalanced Wheels to produce the Bessler Wheel effect – rotate forever. (Yuen Wheel).
·        Re-examine existing Pulse Wheels to see the resonance (or pushing pendulum at right time) mechanisms.  Check that these Wheels are actually at best resonance conditions.
·        Check whether the Chinese or USA Government will release details of the 225 HP Pulse Motor.
·        Pour funding into promising "overunity or free" energy research projects.  Some likely candidates include the WITTS generator or the QEG; the Tong or Ting Wheels; the motionless devices such as the Steven Mark TPU etc.
·        Let some leading Universities conduct seminars and conferences on "Lead-out Energy" research.  Check whether the assumption of leading-out electron motion or electron cloud energy is correct.
·        Get one or more Lead-out Energy devices to produce 5KW for the average home and solve the energy crisis forever...
I would not advise pouring too much resource into pure gravitational devices.  It is like human muscle flight.  The leading-out of magnetic and electromagnetic energy is more practical.
God Bless.
tagor
