0 Members and 93 Guests are viewing this topic.
ltseung888
 Let us plan on the Pulse Wheel experiment.
The assumptions are:
1.  Use the bicycle wheel with one lead weight as the unbalanced wheel. (already available)
2.  Use one Coil and one Magnet to start.  Magnet is the available round type.
3.  The magnet is to be at same position as the lead weight.
4.  The diameter of the coil is same as that of the magnet.  The number of windings starts at 100 in increments of 50 turns.
5.  The DC power supply unit is used as the Input Source (available).  Start at 6 Volts and increments at 3 volts.
6. Use an Atten DSO to determine the Input Power with spreadsheet analysis.(available)
7. Start with no load.
8. Use optical sensor to turn DC Current ON.  Use another optical sensor to turn DC Current OFF.
The Tong wheel experience told us that one air coil and one magnet at 12V can keep the large wooden wheel turning.  We shall be more systematic this time.  We shall use iron core to get maximum magnetic forces.
The goal is to find the minimum Input Power to keep the unbalanced wheel rotating with no Load.  Learn as much as possible before the next step.
Morality Point:
The early Tong Wheel development was "rushed".  Get the wheel spinning and simply put more coils and magnets.  Check for overunity.  The apparent success (Input and Output at a few watts) blinded us to doing more vigorous research.  The Tong Wheel was shown to investors and academics.  It was taken apart multiple times and finally the wooden structure broke.  One incident convinced us that the 225 HP Pulse Motor was not a hoax was – in one tuning experiment with the 12V battery connected, the voltmeter suddenly shot to its limits and the internal fuse was burnt.  A section of the Tong Wheel was charred.
We could not and did not determine the exact condition again.  It was assumed to have touched on some "resonance".  The follow-on tunings were done with the 12 V battery disconnected.  (Tong got HK$130k to do another prototype.  We also got over HK$250K for the FLEET development.  The team fell apart with the HK$3 million promised funding.)
When money was tight, there were few disputes.  When money was looser, there were disagreements on the directions to take.  Ego overcame reason...
ltseung888
The improved Pulse Wheel - unbalance it with lead weight?
The Chan Wheel taught us that gravitational energy cannot be brought-in via a balanced wheel.  A pulsed Unbalanced Wheel mounted vertically can bring-in gravitational energy in every revolution similar to a pulsed pendulum.
A simple arrangement is shown.
The concept appears to have been confirmed by the Peru, Chas Campbell and Ting wheels in a similar fashion.  In particular, Dr. Ting got the axle twisted when he added a heavy unbalanced wheel on the same axle as his pulse wheel...
Morality Point:
Every one can look but none can see for decades???  Is it Divine Revelation?
noonespecial
ltseung888
Quote from: noonespecial on January 19, 2015, 05:40:58 PM
Looks familiar :) . Here's the first machine I ever built 6 years ago:
https://www.youtube.com/watch?v=cViZJ90xRxY
Dear noonespecial,
You have done much great work on the gravity wheel devices.  Your help will greatly add to the knowledge and the implementation.  Some questions:
1.  Have you determined that one or more of your devices produce more Output Energy than Input?  Or are there strong grounds to believe so?
2.  Have you ever considered "Lead-out" energy as an explanation?  Have you checked on the mathematics of the horizontally pulled pendulum?
3.  Have you tried to put an Unbalanced Wheel on the same axle of a "normal motor" and check the increase in torque?  If so, have you fed that to the Input of another more powerful "normal motor/generator"?
Thank you in advance.
Morality Point:
The energy multiplier device we discussed at Tsinghua University 8 years ago may be using "unbalanced cylinders" to bring-in gravitational/magnetic energy.  It was working in a factory and claimed to use one eighth the electricity.  Initially, the local electric company suspected them of "stealing electricity"...
If the Milkovic 2SO, Chan Wheel and Skinner devices can bring-in gravitational energy, other gravity devices may be able to bring-in gravitational energy also.  The Bessler Wheel may not be a hoax.  Are we getting closer to understanding the secret of the 225 HP Pulse Motor???
ltseung888
just a thought
Would the addition of an Unbalanced Wheel make the QEG overunity?  Use a proper Unbalanced Wheel to bring-in gravitational energy at resonance...
