0 Members and 25 Guests are viewing this topic.
ARMCORTEX
I have already layed out all the best concepts and concrete explanations for mechanical devices.
Wich far surpasses all that Ltseung has shown and goes beyond milkovic.
on my yt , skyrinninjamod
I, with Charlie, are certified pros and our word is final.
There is also the universal engine, wich could be discussed.
But I havent seen anythingt from those guys yet.
norman6538
The hand pump needs to be properly balanced to the weight of the
water column and the pump rod mechanism and the handle so that
the person is only lifting one cycle of water a few inches. That is why
the handle is long and often weighted on the end. But remember that
a given pump is not tuned to the various well depths.
So you can see then that if tuned the work done is merely lets say
lifting half a gallon of water maybe 6 inches which is quite easy.
Then if you add the Milkovic factor its even less. But if its really
9:1 then it should run by itself. I have not seen that yet. Have you?
Norman
norman6538
OK folks, here's my challenge. If the Chan wheel is OU then they can be cascaded
together such that a small one is cascaded to larger and larger ones such that
a small child can turn a wheel similar to a tricycle wheel and in turn lift up his
parent at the other end of the cascaded devices.
And then build these in public places such that  the whole country can see OU  right in front of their faces.
Wouldn't that be quite a movement. Far greater than a football game or a Rube Goldberg entertaining contraption.
But the nasayers say it can't be done...Lets see guys. Lets just do it.
Norman
Paul-R
Quote from: norman6538 on January 23, 2015, 09:27:18 AM
... That is why the handle is long and often weighted on the end...
You must be thinking of the traditional design water pump. This model has no handle; only a pendulum which we keep swinging.
An electromagnet giving a pulse at the right time will keep the pendulum swinging, and give us "Energy in".
The rate of flow of water times the final overall height gain will give the "Energy out".
(keeping the units consistent and for a set amount of time).
ltseung888
The attached diagram shows the experiment to be done by us in the next few weeks.
The same or similar experiment was done by other groups.  The one I am aware of was - using cylinders instead of wheels.  A cylinder can be treated as multiple wheels placed together.  (The Tsinghua University Energy Multiplier.)
Whether the simple Unbalanced Wheel can lead-out gravitational energy can be demonstrated should not be too difficult.  From the experience in tuning the other Pulse Wheels, I believe we need to hunt for "resonance" conditions.  The efficiency of the set up dramatically increases at certain rotational speeds.  (pushing the pendulum at the right time.)
Are any of you in a position to do such an experiment?
How do you measure the various entities: Input Power, Output Power Torque, rotational speed etc?
Morality Point:
The Chan Wheel is easy to construct but the implications are...
Any motor A can drive a more powerful Generator B using the lead-out gravitational energy.  B can then power Motor A and we have a  self loop...  QEG can be turned to WITTS.  Do we need resonance conditions???
Morality Point:
Old Tseung cannot even tighten a screw properly.  Asking him to do experiments is like asking a one legged man to win the Olympics.  But the one legged man can cheer and even advise the Olympic winners...
