0 Members and 80 Guests are viewing this topic.
ltseung888
Quote from: Paul-R on January 23, 2015, 09:07:47 AM
The problem is to realise the energy inherent in the raising of the weight; I think we need to get back to the simplicity of the water pump
http://www.rexresearch.com/milkovic/milkovic.htm
What would happen if the pulsed pendulum is replaced by a rotating Unbalanced Wheel powered by a small electric motor?  Can the Input Power be measured accurately?  Can the Output Power (water to be raised to a given height) be measured accurately?
Can we confirm OU for Milkovic and Chan Wheel with such setups?
Morality Point:
Small swings of an Unbalanced Wheel act exactly like a pendulum.  That implies that almost anything a pendulum can do, an Unbalanced Wheel can do.  But the Unbalanced Wheel is more powerful in that it can have 360 degree rotation and that the rotational rate can be much higher.  The higher rotational speed will give rise to higher centrifugal force and much more gravitational energy can be brought-in during the same period.
Milkovic and supporters will soon agree with the above fact.  Their research will rise to a new level...
ltseung888
Quote from: norman6538 on January 23, 2015, 09:49:15 AM
OK folks, here's my challenge. If the Chan wheel is OU then they can be cascaded
together such that a small one is cascaded to larger and larger ones such that
a small child can turn a wheel similar to a tricycle wheel and in turn lift up his
parent at the other end of the cascaded devices.
And then build these in public places such that  the whole country can see OU  right in front of their faces.
Wouldn't that be quite a movement. Far greater than a football game or a Rube Goldberg entertaining contraption.
But the nasayers say it can't be done...Lets see guys. Lets just do it.
Norman
The Tsinghua University Energy Multiplier has 3 sets of cylinders...
ltseung888
Quote from: TinselKoala on January 21, 2015, 01:48:21 PM
You can use "one-way" bearings that are readily obtained from your local hobby shop that sells RC helicopter parts, with matching precision shaft inserts. This will not change the geometry of the system.
http://www.aligntrexstore.com/One-Way-Bearing-New-HS1229-for-T-Rex-450_p_76.html
http://www.helipal.com/hz026-one-way-bearing-shaft.html
Experimenters doing these tests should review some basic engineering dynamics first, so that they do the calculations _correctly_.
http://hyperphysics.phy-astr.gsu.edu/hbase/torq2.html
Dear Tk,
I found the following video you posted a few years ago.
https://www.youtube.com/watch?v=rXpEqoDJDbM
Have you tried to use an Unbalanced Wheel mounted vertically to check on the same Minato Effect?
We also found similar effects a few years ago using a Balanced Wheel.  Now we want to repeat using an Unbalanced Wheel but the old setup was "gone".
You may be able to reproduce your setup and unbalance it...
Morality Point:
Minato may have already demonstrated leading out of magnetic energy.  Pulsing it with gravitational energy may reveal new knowledge...
God Bless,
Lawrence
ltseung888
Last two slides of the presentation.
Note that we recommended approaching WITTS.  My belief is that the WITTS Generator is no hoax.  We may be able to add an Unbalanced Wheel to QEG and make it closer to WITTS.
However the diameter and the unbalanced Weight may produce different resonance conditions.  Tuning it to match the QEG observed resonance may need some work...
Donations may ease the work.
Paul-R
Quote from: ltseung888 on January 23, 2015, 02:40:21 PM
Why bother?
All we need is an electromagnet and a timing device
