ltseung888
Quote from: noonespecial on February 10, 2015, 12:41:35 PM
I may have missed a response but don't know who Chas Chandler is (did you mean Campbell?). My point was that if there isn't a second degree of freedom (i.e. Milkovic, et al) l don't see any advantage or 'lead in' energy.
In your video (and many others), you found that the Input Energy seemed to decrease after rotating the unbalanced wheel.  If you pulse (or supply energy) to a pendulum, the amplitude of oscillation will increase.
The Lee-Tseung lead-out energy states that some gravitational energy is actually brought-in to provide the increase.  For small angles, two parts of the energy is the supplied pulse energy.  One part is the lead-out or brought-in gravitational energy.
If you supply energy to an unbalanced wheel, it will rotate faster.  At the same time, it will lead-out gravitational energy to make the rotation even faster.  I have not worked out the ratio yet...  The difficulty lies in the rotational friction.  If that is reduced, both balanced and unbalanced flywheels rotate freely independent of the weight of the wheel.
In the case of the unbalanced wheel, supplying more Input Energy may increase the shaking and destroy the device.  (Dr. Ting was very upset when his wheel axle was twisted.)
noonespecial
Quote from: ltseung888 on February 10, 2015, 06:15:25 PM
A balanced flywheel will store mechanical energy and smooth out the rotational speed.  It will not oscillate to lead-out gravitational energy.
An unbalanced wheel is essentially a flywheel with an additional weight attached to the rim.  It will store mechanical energy. It will produced the oscillation motion to lead-out gravitational energy.
The number of oscillation is once per revolution.  Engineers in the past automatically dismissed unbalanced wheel or cylinder because of the vibration or shaking that would "destroy" the structure.  They did not realize that they could lead-out gravitational energy.
Please see the Chan Wheels videos on Youtube.  Focus on the comparison - balanced bicycle wheel will not lift the weight no matter the rotational speed.  Unbalanced bicycle easily reproduced the Milkovic effect...
But again, this only works if there is more than one degree of freedom. For instance, the Chan wheel would lift absolutely nothing and be totally useless if it was not allowed to fall. An unbalanced flywheel does nothing without a second degree of freedom.
noonespecial
Quote from: ltseung888 on February 10, 2015, 06:30:20 PM
In that particular video, there was 2 degrees of freedom for the unbalance weight.
Not to sound like a broken record, but without that second degree of freedom you do not maximize the effect. Do you agree?
ltseung888
Quote from: noonespecial on February 10, 2015, 06:31:06 PM
You are correct in pointing out the "second degree of freedom".  I attributed the shaking as a "second degree of freedom".  If not properly used or released, this second degree of freedom may destroy the device.
Both the Milkovic and Chan wheels use lifting weights to use or release the energy.
The Pulse Wheels such as Wang, Tong and Ting wheels use external loads to release the energy.  The Chas Campbell and the Tsinghua Energy Multiplier use another Generator to use or drain out the energy.
Paul-R
Yes, I did. Sorry. (Chas Chandler was the bass player of "The Animals").
