ltseung888
Meetings at Hong Kong University.
Prof. "I got your email.  It looks like you have made much progress."
Tseung: "The technical evaluators from two separate Venture Capital groups did some tests.  They indicated that the Unbalanced Wheel or Cylinder might indeed lead-out gravitational energy.  However, they are unlikely to disclose the details as the information has commercial value."
Prof. "What can I do for you."
Tseung: "I have contacts claiming that they could put down some research funding.  They are wealthy individuals.  Donating HK$1 million is within their capability.  They asked me whether I could find a team to further develop the Lead-out Energy Technology."
Prof: "I may be able to find some students or research students after May.  Can you wait?"
Tseung: "The lead-out energy theory has been out for over 10 years.  A few more months will not make much difference.  I shall also meet one of the research students who said that he would like to work on the project."
ltseung888
Meeting with the Research Student.
Student: "I am glad to meet the person himself.  I read the lead-out energy theory and I am excited."
Tseung: "Tell me more about your background."
Student: "I graduated from Tsinghua University and is continuing my higher degree at Hong Kong University.  I first learned the lead-out energy theory at Tsinghua University from a recorded lecture."
Tseung: "Have you worked with or have you seen the Tsinghua University Energy Multiplier?"
Student: "I heard about it but I have not personally worked on it."
Tseung: "We are thinking of doing the experiment with a motor driving an unbalanced cylinder to lead-out gravitational energy.  The setup will then drive a generator.  We hope to demonstrate that the lead-out gravitational energy is large enough to overcome all losses.  We can then conclusively demonstrate that we can use the lead-out energy to power other electrical appliances and may even self-loop."
Student: "I am aware of that.  I would like to have an opportunity to take on the challenge."
Tseung: "I shall work with the professor and the funders on the details.  I shall keep you informed."
The going rate to employ a summer student is HK$3,000 per month; for a new graduate is HK$15,000.  We expect much ground work will be done before May.  The actual prototype(s) will then commence and would complete within 3 months.
The Chan Wheel took 2 months and the total cost was HK$20,000 including rent, wasted material, travel, meals etc.  (Labor and brain - the most expensive items - were free.)
It reproduced the Milkovic 2SO effect in lifting the weight.  It further showed that a balanced wheel would not lift the weight.  It proved or hinted that the unbalnced wheel with the centrigual force generating the oscillation would lead-out gravitational energy.  The money and time spent was worthwhile.
ltseung888
Let us focus back on the Tsinghua University Energy Multiplier.
I believe that there should be a belt tightening mechanism.  When Motor A starts, the rotation speed will be slow.  Not much gravitational energy will be brought-in.  When Motor A increases in speed, larger torque and some mechanical energy will be brought-in and stored via the Unbalanced Cylinder.
The belt can then be tightened to drive the second axle and the Generator.  What kind of mechanisms are available?
Eout = Ein + (Egravity - Eloss)
Can we make Egravity much greater than Eloss?
ltseung888
The attached information is being sent out both via email and hard copy to as many people as possible in Hong Kong and China.  You are welcome to help to spread the information to the rest of the World.
Hopefully, enough interest will be generated in the academic, business, engineering and political circles before May 2015.
Real prototypes that will be open sourced to the World are likely to start in May.  For-profit organizations have started work.
The Divine Wine is for all to share.
Unbalanced Wheels or Cylinders can lead-out gravitational energy in appropriate conditions.
Paul-R
Quote from: ltseung888 on February 13, 2015, 07:38:29 PM
Not without understanding what Egravity is, how it happens, where it comes from and why it happens.
I have asked in the past and never received any sort of answer that I found useful.
