noonespecial
Quote from: ltseung888 on February 20, 2015, 02:21:19 AM
Since I do not read Russian, I cannot cofirm for sure.  But I did see a drill and two small "gravity arms".  I could not determine how he used the lead-out gravitational energy.
Can you please elaborate?
Such videos help to provide me with more confidence that the experiment will be a success.
This is a full rotation type of two-stage oscillator. The drill drives the first unbalanced weight which is mounted on a common platform with an un-driven second unbalanced weight. The platform is cantilevered and supported by a heavy compression spring that provides the 'bounce' to induce rotation/oscillation in the second unbalanced weight.
He attempts to show a 'load' by pressing a section of hose against the drive-train. Near the end, the induced rotation falls out of resonance and he cuts off the power.
The problem at the end is what I have seen in my experiments as well. You can induce a secondary oscillation as long as you remain within a resonance 'window'. Once your load exceeds this window, the secondary oscillation falls apart.
I only meant to show that your experiment is similar but superior because there is no two stage oscillation.
noonespecial
Quote from: ARMCORTEX on February 20, 2015, 12:18:19 AM
Yes I am talking about the 2 minute video of Chas and the 2 other guys.
The VFD is only a proposal wich Chas cares nothing about, he seems to not care for those guys at all.
Basicly, that video says very little, in fact the device is mostly disassembled.
I wonder why this is all that was shown.
I am talking about the wheel that gets released by the holder, it is freefloating.
Here's the dialogue:
2:41 Charles: "I can get it (the motor) to spin in the belt as you've seen it without doing any damage to the motor. Well I'm not actually doing damage but I don't want the motor overloading while I'm trying to build it up."
2:57 Second person: "What we can also do is have permanent tension on there and use a VFD."
3:05 Charles: "Yes, there are probably better ways of doing it...the easiest way for me to do it (start the device) was to have loose belts...that doesn't mean to say..."
(Second person): "and that's the clutch there?..
Charles: "Then I just wind up this little thingy and this a purely a guide so that it tries to come up straight plus a spring to put a bit of tension because I don't want it to tip over once I get the pulleys right."
Its clear to me that the loose belts only serve to be able to start the entire machine. Otherwise, he would burn out the motor because the initial load is too great.
ltseung888
Quote from: noonespecial on February 20, 2015, 12:14:50 PM
Thank you for the explanation.  I have looked at the universal engine video multiple times.
http://www.universalengines.com.au/
I like the name "universal engine".  Their mechanism is far too complicated.  The Tsinghua Unbalanced Cylinder is far superior.  The unbalanced weight is inside the cylinder and would not flying out.
The Unbalanced Cylinder is the Universal Engine.  That is the State Secret of China.
Now I think I know why I was suspected as a spy in 2006.  The technology is extremely powerful but simple.  Any developing nation can master it.
The Unbalanced Cylinder can be scaled up and down to lead-out gravitational energy.  This is only the beginning.  Leading-out magnetic and electromagnetic energy follows.  The Military of China and USA both realized its potential.
Lee Cheung Kin is right.  I am only a kindergardener compared with the Establishments.
The magic is revealed.  The Unbalanced Cylinder can be a Universal Engine.  Gravitational Energy can be lead-out in the simple motor-cylinder-generator arrangement.  Patents are not allowed because it is a state secret.
But any small nation can come out with Unbalanced Cylinders as add-on products...
ltseung888
Quote from: noonespecial on February 20, 2015, 02:47:56 PM
I agree. The Tsinghua Energy Multiplier may have similar mechanisms.
ltseung888
Another more general design for the Tsinghua University Energy Multiplier.
Unbalanced Cylinder acts as Universal Engine Enhancer.
Many machines can use this design to bring-in gravitational energy as the source of Power.
However, the more compact designs will bring-in magnetic or electromagnetic energy.
