0 Members and 125 Guests are viewing this topic.
ltseung888
More calculations.
1. The energy lead-out per swing for the Milkovic 2SO is (m1-m2)gh.  m1gh is the potential energy shown in lifting the weight m1.  m2gh is the potential energy required to return the pendulum back to its original position.
2. The energy lead-out per swing of the Unbalanced Wheel oscillating as the Milkovic 2SO is (m1-(m2+m3)gh where m2 is mass of the wheel and m3 is Unbalanced Mass.
3.  If there were no m1 to be lifted, the maximum potential energy difference per revolution is 2m3gR where R is the radius of the Unbalanced Wheel.  The actual amount will be much less than that.  If there were no oscillation motion, the force will change but there will be no displacement and thus no energy.  If there were vertical movement or oscillation, energy will be lead-out.  Another possible conversion is for the Unbalanced Wheel to rotate faster.
4.  The maximum energy lead-out per unit time =  2m3gRw where w is the number of revolution per second.
5.  Another way of looking at the scenario is the total vertical distance moved ignoring the direction.  In other words, it is the maximum peak-to-peak amplitude of oscillation.  The exact conversion mechanism is still not absolutely clear yet...
6.  If the oscillation energy were instantly converted to rotation, the energy can be stored and transferred to another axle (and to the Generator).  This may be the secret of the Tsinghua University Energy Multiplier.
The Taiwan setup uses magnetic suspension, allowing the axle itself and device to oscillate up and down.
Morality Point:
It took 10 years before the above calculation is clear in my mind.  But once it is clear, the Tsinghua University Energy Multiplier is a certainty.  If gravitational energy can be lead-out, magnetic and electromagnetic energy can be lead-out.
The Divine Wine has matured.
ltseung888
The scientific question.
A system is in State A.  It can do work or transfer some of its energy to the surrounding environmnt.  Assume that the work done is Z.  The system is now in State B.
In an ideal situation, Z amount of energy must be supplied to bring the system from State B back to State A.
Is it possible to supply X units of energy from the user and bring-in Y units of energy from the surrounding environment so that X+Y is equal to Z?  The system will then be returned from State B to State A.
ltseung888
Quote from: ltseung888 on February 23, 2015, 05:48:36 PM
The theoretical answer must be YES.
The practical question to follow is HOW?
The actual devices are the Milkovic 2SO, the Chan Wheel, the Tsinghua University Energy Multiplier etc.
The Divine Wine...
ltseung888
Conversation with Mr. Peter Chan - the Engineer who built the Chan Wheel.
Chan: "My son talked with his professor.  His professor did not think the project would work.  However, my son expressed interest to participate after his studies."
Tseung: "We expect the classical rejection.  This is just another confirmation."
Chan: "Can we do a small scale experiment?  Most mechanical systems can be scaled up or down."
Tseung: "For static systems, your statement is true.  However, the lead-out energy systems use dynamic (more exactly, centrifugal) force that increases with the square of the angular velocity.  The scaling down may not work."
Chan: "Have you approached the academics?"
Tseung: "I talked to Mr. Lee Cheung Kin over the holidays.  He said that the Tsinghua University Energy Multiplier was a Sate Secret 10 years ago.  It might still be a State Secret today.  However, our kindergarten level work might be "tolerated" by the authorities."
Chan: "We can do other experiments that we enjoy.  We just do not build products."
Tseung: "Let others shine.  I have passed the one page handout to other groups such as Thailand, India, Philippines etc.
ltseung888
There are already over 40 motot-generator projects as reported by Sterling Allan.
http://peswiki.com/index.php/Directory:Motor-Generator_Self-Looped_with_Usable_Energy_Left_Over
The Tsinghua University Energy Multiplier need not be a State Secret anymore.
