Pirate88179
Quote from: ARMCORTEX on March 01, 2015, 04:46:38 PM
https://www.youtube.com/watch?v=EFpnsMTHgRM
According to resonant fractals, we must add pulse to the slingshot.
whatever that means.
http://www.resonantfractals.org/Magnetism/Flywheel.htm
It would seem that mankind has already found two methods of gaining Over unity energy in orbital systems.
In the one case we have a sling shot orbital maneuver, the second in the mass of a rotating wheel being pulsed under powered acceleratio
Unless I am wrong...and I might be...the orbital slingshot is not overunity.  As in the case of Apollo 13, it simply allowed their return without any additional energy added from the spacecraft.  They were already moving faster than 25,000 mph (escape velocity from the earth) and going around the moon simply sent them back toward earth where a few course correction energy inputs needed to be added to maintain their course.
This saved massive amounts of energy required to decelerate and stop, and then accelerate back toward the earth.  Actually, I don't think this was an option as that would have required more energy than they had in fuel on board.
ARMCORTEX
Hello Pirate,
No he mentions lower in the text the slingshot as being also pulsed.
He does a bad intro about that one.
ltseung888
Now that the discussions are on scientific basis, I would like to add the following:
1.  The varying Centrifugal Force of the Unbalanced Wheel or Cylinder will cause the axle to vibrate.  This vibration or oscillation will lead-out gravitational energy.
2.  If this additional energy is immediately transferred via a loose belt pulley system to another axle, the lead-out gravitational energy does useful work. (Chas Campbell arrangement)
3.  Even in the case of a perfectly balanced wheel, if we couple it with a loose belt pulley system, a vibration will be produced.  This vibration will also lead-out gravitational energy.
4.  Thus it appears a belt type system is better than a tooth type system if we want to lead-out and use the lead-out energy.
5.  Can we consider the vibrations caused by the varying Centrifugal Force as pulses?  Control via transferring the energy via belt and pulley to another axle?
Pirate88179
Lawrence:
With all due respect...I disagree totally.
#1  The vibration will cause or induce additional friction which is never good in any rotating device and is a negative. It is a big loss in efficiency.
#2  A loose belt is also another good way of introducing a loss into any belt driven system.  Your car alternator does not charge your battery as it should with a loose belt.  This is a loss of efficiency...not a gain.
#3  See 1 and 2.
#4  This conclusion is wrong.  A toothed belt stops slipping which aids in a belt driven system.  A slipping belt produces heat, which in this case would seem to be a waste of the input energy right?  There is no way a system like this can offer any ADDITIONAL energy from the input...only losses that are far less than was is put in.
ltseung888
Quote from: Pirate88179 on March 01, 2015, 05:41:21 PM
Lawrence:
#3  See 1 and 2.
Can some of the heat be due to lead-out gravitational energy?
Can we transfer such gravitational energy fast enough to prevent excessive vibration and heat production?
Think outside the box...
The Tsinghua University Energy Multiplier is not a hoax.  I am sure that a good experimenter or organization with proper resources will be able to reproduce it.  Unbalanced Wheels or Cylinder are not that difficult to make.
I am not the one to make it. Let others shine.
The scientific observation is that the balanced Chan Wheel will not lift the Weight.  The Unbalanced Chan Wheel will.  This can be confirmed easily worldwide...
The Taiwan Maglev QMOGEN system suspends the axle on magnets.  The axle is allowed to move up and down.  The Maglev has been demonstrated on TV and are gearing for production.  Controlled vibration is good?
