ltseung888
The Taiwan Maglev.
One thing to note about the Taiwan Maglev is that it uses magnetic repulsion to "float" the device.  There is little friction in the axle rotation.  The axle can actually "vibrate" up and down without causing harm to the rest of the device.
It is also a QMOGEN using lead-out Energy.  I shall check further whether the lead-out energy is purely gravitational or does it already lead-out magnetic or electromagnetic energy...
Lawrence
see reply 2826
ltseung888
Quote from: webby1 on March 13, 2015, 07:51:45 PM
Not by my testing.
I shared a lot of my results in the Skinner thread,, ones I thought were looking good and not so good but in the end with the way the device is presented there is not a gain that I could find,, I would of even settled for a large loss because if you can loose it you should be able to find it.  All things I did loose I could account for.
Your rate of rotation leading to a gain also does not work by my testing and a sim that was done to measure values that I could not.  You end up with a give and take system and that becomes a net zero condition,, you see a gain in one area but then there is an increase in input in another to make that gain.
I get the math but remember when dealing with things in orbit that there is a cost as well when that orbit is forced into a deviation,, you let it fly off in this direction and you have to grab it,, this is the part you are calling a gain,, but guess what, the weight is traveling in the wrong direction,, so now you have to pull that weight back and then you have to accelerate it back up to speed.
You may use the outside force to stop the fly-away,, and how much of that you use up also means that is the amount of acceleration YOU need to add back in,, see there is the rub,, YOU are putting back in what was taken out.
These are some of the things I have observed from actual builds,, as I suggested, you should do the test and see for yourself.
Once you build the Chan Wheel or the Tsinghua University Energy Multiplier, you will see things differently.
I am not an engineer or a mechanic. I shall NOT build things myself.
There are over 50 QMOGENs and more are coming.
I prefer to work with others who have a working device.  Taiwan Maglev is an example.  I just help them to remove the road block.  Their device is not the impossible perpetual motion machine.  It is a possible lead-out energy device.
Lawrence
see reply 2826
MarkE
Quote from: ltseung888 on March 13, 2015, 07:44:32 PM
It does not matter whether you disagree.  The lead-out energy is there.  The super-set Chan Wheel leads-out much more.  The Super-super set Tsinghua University Energy Multiplier leads out even more.
Look at the William Skinner device.  Does it lead-out gravitational energy via Unbalanced Wheel rotation?
Lawrence
see reply 2826
Now you are just lying.  There is no output energy at all.
Paul-R
You guys are sounding a bit like ISIL nutbags.
At least you are not beheading each other with kitchen knives.
For this, I think I can safely say, we are all truly grateful.
Pirate88179
Lawrence:
Why not post a link to your 4-legged stool experiment video to demonstrate what you are talking about?
As you know, I do not believe in your theory as there really has been no experimental evidence to suggest it is valid. (As far as I know)
Also, I remember Forever doing a pendulum experiment that you said showed the lead out principle, do you have a link to that one as well?
