PIH123
Quote from: ltseung888 on April 01, 2015, 09:22:07 PM
4.  The flying saucer can go in a spiral path using centrifugal force.  It can use thrust to weight ratio less than 1.  It can also fly in space. It may appear to be stationary similar to a helicopter.
Larry T,
I know you either won't read this or will completely ignore it but here goes.
You state that the "flying saucer" is using a spiral path, gaining thrust via centrifugal force from this.
So how can it possibly maintain a stationary aspect without the spiral path ?
There is so much else that can be mentioned (like you knowing US and Chinese secrets - not very good secrets then are they?), but what is the point, since you will not respond to any critical evidence.
But ................. The reason that I bring this up is because in your "communication to Motor Manufacturers" (eg. see Reply #2963 on: March 19, 2015, 11:29:25 PM)
you point them in your letters to this thread:
such as - "Details are in http://www.overunity.com/1763/12-times-more-output-than-input-dual-mechanical-oscillation-system/msg442672/#msg442672"
A smart potential investor / partner will most likely browse the entire thread (including the newer entries) and not just the hand picked posts you want them to see. This should give them a good understanding of your overall level of credibility.
So at least anyone you have contacted can see the path you are taking now and know not to get involved.
Low-Q
Let's talk about easter eggs. How did they populate the world, and did they arrive secretly in a spiral fashion?
Did they arrive in a centrifugal black vortex hole without legs and bunny feets?
Vidar
ltseung888
Quote from: PIH123 on April 02, 2015, 11:42:06 AM
Larry T,
A tight spiral will appear stationary.
My task is to sow seeds.  I do not have the resources to build a Flying Saucer.  But many Governments do.  The USA and Chinese Governments already built them.  Some of their test prototypes mistakenly flew outside the controlled areas and got photographed.
When an object is moving in X direction and if a perpendicular force is applied, the object will turn very tight circles - including flying back at 180 degrees.  The behavior of a flying saucer is easily explained once we apply circular motion concepts...
The Physics is undeniable.  The Centrifugal Force or Circular motion aspects need to be re-evaluated.  The Milkovic 2SO, the Chan Wheel, the Skinner Device, the Tsinghua University Energy Multiplier all used such technology to lead-out energy.  This field will also allow flying to outer space and have the energy replenished...  It is better than reversible chemical reactions.
Some seeds will fall on rocks.  Some will be eaten by birds.  Some will bear fruit.
Lawrence Tseung
see reply 3038
ltseung888
I now have email from an Asian motor manufacturer interested in the Flying Saucer.
Will this seed bear fruit?
Divine Wine is for all to share.
Lawrence Tseung
see reply 3038
PIH123
Quote from: ltseung888 on April 02, 2015, 03:50:15 PM
Sorry, that is less believable than the TsingTao (intended spelling) university multiplier.
As has been mentioned before, you are a likeable guy.
You do not curse in your posts (unlike that Theoria A-pot-to-piss-in).
You are steadfast to your beliefs, and I believe you genuinely want to make a difference.
I think you would be better suited to leave the flying saucer thing out of this thread if you want it to be viewed and taken seriously by potential partners.
Your statement in the previous posts
QuoteThe USA and Chinese Governments already built them.  Some of their test prototypes mistakenly flew outside the controlled areas and got photographed.
makes no sense.
A government has the EXTREME technology and is capable of building flying saucers, but fails to pilot them within a controlled area.
USA and China are the 4th and 3rd largest countries in the world, with tens (if not hundreds) of millions of acres of  military land.
And they go and accidentally fly the number one most secret technical advancement ever over a populated area for a photo session.
Come on man. Have some pride in what you are posting.
Pete
