Paul-R
Quote from: ltseung888 on April 05, 2015, 01:46:35 AM
Great.  You may be one of the first scientists on this thread to answer the following:
Bernoulli's Principle states that the pressure exerted on the side direction of a moving fluid will be less.  This is the normal answer given to why airplanes fly.
My question is:  Does Pressure have direction?  Is Pressure a scalar or a vector quantity?
Scalar.
Bernouille states that the  energy at any section in the flow will be the same, and so, if the velocity goes up - due to the longer, curved upper surface of the wing, the pressure goes down. This reduction in pressure causes an upward suction on the top of the wings - aka lift.
This is principally as manifested in David Beckham's famous goal scored from the corner with a corner kick - then called the Magnus Effect - possibly during the World Cup - was it versus Ecuador? (I suspect that goalie must still be getting nightmares).
ltseung888
Quote from: Paul-R on April 05, 2015, 10:15:00 AM
Scalar.
Let us wait for PIH123 - a real professional in aerodynamics.  In the Internet, a layman and an expert can post.  Opinions are expected to differ.  The reader has to use his own judgment.
My judgment is that Tsinghua University QMOGEN is not a hoax and has been running since 1996.
  The theory of lead-out energy is correct.  It explains the energy source of the device.  A good number of the over 50 QMOGENs compiled by Sterling Allan are not hoaxes.
It is also my judgment that both China and USA have Flying Saucers in development.  Some sightings and photos of UFOs are the results.
Paul-R, you are entitled to your opinion.  But think about the pressure facing the wind and the pressure perpendicular to the direction of the wind?  Is pressure really a scalar quantity?
My job is to sow seeds.  Let some readers think - can QMOGENs be real?  Can lead-out energy theory be correct?  Are Chinese and USA military developing Flying Saucers if the scientific explanation is laid out here?
Lawrence
see reply 3038 3092
ltseung888
@PIH123,
You may not have seen the posts in another thread many years ago.  The subject of whether something needs to be ejected from a Flying Saucer to provide thrust was discussed.
The concept is repeated here for your comments.
Lawrence
(see reply 3038 3092)
Paul-R
Quote from: ltseung888 on April 05, 2015, 04:23:12 PM
Its not an opinion. It is part of the basic the physics of aerodynamics.
"pressure facing the wind?" You are confusing pressure which is very difficult to sense with the force of the moving air.
A pumped up bicycle tyre has pressure. But there is no difference between the pressure at the front to the pressure at the back of the wheel. Open and valve and let the air out and then the moving  air creates a force.
memoryman
So, Lawrence, in 9 years has this concept been proven? Has it been commercialised? You lack a basic understanding of physics, hence no results.
