ltseung888
Quote from: Paul-R on April 06, 2015, 07:38:09 AM
Its not an opinion. It is part of the basic the physics of aerodynamics.
"pressure facing the wind?" You are confusing pressure which is very difficult to sense with the force of the moving air.
A pumped up bicycle tyre has pressure. But there is no difference between the pressure at the front to the pressure at the back of the wheel. Open and valve and let the air out and then the moving  air creates a force.
Let us wait for PIH123.  Pressure in a non-moving environment will be the same in all directions.  But in motion...  Your understanding of aerodynamics will be challenged.
ltseung888
https://www.youtube.com/watch?v=Hr67j71NSsQ&list=PLvAzms-COt4ZkheBJZ24-p2O8rPef1DHK
The above is a collection of QMOGEN demonstrations.
The lead-out energy explains the source of energy.  The Tsinghua University QMOGEN has been in operation since 1996.
When will a commercial QMOGEN be available?  How many will be bought out by the existing interests?
A QMOGEN on a Flying Saucer...
  The Nanjing UFO on Youtube:
https://www.youtube.com/watch?v=f-_OH6nu7V8
Lawrence
see reply 3038 3092
Paul-R
ltseung888
Quote from: Paul-R on April 07, 2015, 05:54:36 AM
My professor will be most irritated.
Tell him the posts related to Flying Saucers.  Watch his reaction.
ltseung888
From the collection of QMOGENs, some did not use flywheels or unbalanced wheels at all.  They do not lead-out gravitational energy.  Can they lead-out magnetic or electromagnetic energy directly?
I believe the answer is YES.  Let me first list the possible situations that can lead-out gravitational energy.
1.  Horizontally push a pendulum.  The tension of the string will increase.  This increased tension will bring-in or lead-out gravitational energy.
2.  The Milkovic 2SO effect.  The Centrifugal Force will be highest when the bob is at the lowest point.  This plus the weight on the RHS will produce a higher clockwise moment and raise the Weight W1 on the LHS.  Gravitational energy is brought-in.  The Chan Wheel is the improvement.
3.  The athlete on a trampoline will exert the jumping force at the right time.  The re-bouncing force plus the jumping force will send the athlete up higher with each successive jump.  Some gravitational energy is brought-in to provide the greater height.
4.  A rotating unbalanced wheel at the end of a spring.  There will be vertical oscillation of the spring.  If the period of rotation matches that of the spring, the successive pulls will reinforce and bring-in gravitational energy.
5.  An unbalanced cylinder is effectively a super set of unbalanced wheels.  It can lead-out more gravitational energy.
If gravitational energy can be lead-out, magnetic or electromagnetic energy must be able to be lead-out in a similar fashion.  This can be proven with the horizontal magnetic pendulum.
Thus, it is likely magnetic or electromagnetic energy can be lead-out in an oscillation system or rotating system.  Almost all electric motors or generators have rotations.  Leading-out magnetic or electromagnetic energy is theoretically possible.
My recommendation is - do the simplified Tsinghua University QMOGEN first and confirm that the unbalanced cylinder can lead-out gravitational energy.  Add this unbalanced cylinder to almost all rotating systems and bring-in the gravitational energy.
At the same time, find a pair of motor and generator that is commercially available and produce a QMOGEN for all to replicate.  This is being done by the Chinese (and other?) power motor manufacturers.  They already produce a series of motors and generators.
The top secret of China and USA on Flying Saucers and QMOGENs are out.  The secrets of the 188HP Laing Car and the 225HP Pulse Motor are unlikely to be kept for long.
Sterling Allan may be in jail but he can be sure that his effort in compiling QMOGENs is not wasted.
Divine Wine is for all to share...
Lawrence
see reply 3038 3092
