ltseung888
Quote from: webby1 on May 22, 2015, 06:24:36 PM
I am very aware of that approach.
Here is a pic of DRUM,, Dual Rotor Useless Motor.
I used this for a few counter rotating force kind of things,, I could make it lift one corner,, rotate,, drop a corner,, all sorts of things except get lighter.
This one is interesting because all of the normal case torques and forces are internally canceled,, so I can spin it up as fast as I want, as quick as I want,, using the drive coil, without anything else changing or moving,, unless I decide to put a secondary resistance in place that the case sees,, I can also decelerate it using the drive coil without anything else changing.
Great.  Examine the fifth design diagram in reply 3302 again.
With two counter rotating PM in donut tubes, we can have two net centrifugal forces going up.  Other forces cancel out.
I am sure that the USA and Chinese Military have such prototypes.  If they did not have it last week, they will have it now.  Other Nations can develop it in no time - Russia, Japan, India...
ltseung888
Attended a funeral service of a Political Figure.  He was willing to speak his mind and took on controversial positions.
One of his famous quotes: "It is more important to clearly state one's political stand than to worry about one's reputation."
My stand is - lead-out energy flying saucer is a certainty.  It must be developed to benefit the World.
The pastor said: "Trust in the Lord.  He will guide you to walk on the right path."
One group of University students said: "Centrifugal Force is greater if the angular velocity is greater.  This is simple.  There is no need to complicate matters and confuse people."
Lawrence
reply 3156
ltseung888
Quote from: webby1 on May 23, 2015, 08:43:42 PM
Faith is blind Lawrence,, Faith will not build or move things,, it takes work to do that,, it takes effort.
Indeed,, CF\CP go up with RPM or pulse velocity even,, now f=ma and the more "a" the more "f" and the more "m" the more "f".
Then you have the flip side to all that,, the more "f" exerted on the "m" the more "f" is exerted on the coil,, in the other direction.
I do know a few techniques to supply that "a" without having the "f" providing a negative function,, but I will leave it up to you to figure out a method to do that.
I also know a few techniques to remove the velocity,,, but again I will leave it up to you to figure out a method to do that as well.
Let us know when you have something that works.
Reply 3302 got all that figured out already.  Obviously the university students in Hong Kong are better equipped to understand...
There is zero chance that the top military research establishments in China and USA not understanding...
I am sure that they have techniques better than the ones I outlined.
Building an actual flying saucer is beyond my present resources...
ltseung888
In many of the pulse wheel designs (e.g. Tong, Bedini), the permanent magnets and the coils are set at some angle.  Such arrangements do not use the magnetic flux at the optimal.  However, with tuning, they can still show signs of overunity.
Magnetic flux is not stationary.  When another magnet is close or when there is motion, the magnetic flux will change.  It is almost impossible to analyze theoretically.  Much will rely on experiments to check the results.
The best example is the 225 HP Pulse Motor.
With the fifth design of the flying saucer in reply 3302, the magnetic flux may be used in a much more optimal fashion.  Thus it will provide both thrust and lead-out electromagnetic energy.  The electromagnetic energy is likely to be the electron cloud or electron motion energy already present in the magnetic materials.
Lawrence
reply 3156
