Pirate88179
Quote from: ltseung888 on May 24, 2015, 03:37:09 PM
In many of the pulse wheel designs (e.g. Tong, Bedini), the permanent magnets and the coils are set at some angle.  Such arrangements do not use the magnetic flux at the optimal.  However, with tuning, they can still show signs of overunity.
Magnetic flux is not stationary.  When another magnet is close or when there is motion, the magnetic flux will change.  It is almost impossible to analyze theoretically.  Much will rely on experiments to check the results.
The best example is the 225 HP Pulse Motor.
With the fifth design of the flying saucer in reply 3302, the magnetic flux may be used in a much more optimal fashion.  Thus it will provide both thrust and lead-out electromagnetic energy.  The electromagnetic energy is likely to be the electron cloud or electron motion energy already present in the magnetic materials.
Lawrence
reply 3156
There has never been ANY evidence that the 225 HP motor works as described.  None.  None at all.  Do you have any evidence that it does?
ltseung888
I shall briefly repeat the lessons I learned from the 225 HP Pulse Wheel.
1.    The 225 HP Pulse Wheel was funded by Andrew Wong of Hong Kong and developed in USA.
2.   One slice of it was supposed to be shipped to Tsinghua University and I with Lee Cheung Kin was to explain its operation using the Lead-out energy theory in 2006.
3.   The USA Authorities took out all electronics and the slice just contained coils and magnets.  No demonstration could be done.
4.   However, we were able to explain the operation using the lead-out energy theory.  The USA team was impressed and phoned the Headquarters to inform them of the good news.
5.   We made the mistake of explaining the Tsinghua University Energy Multiplier to the USA team at the same time.
6.   When we returned to Hong Kong, we found ourselves suspected as US spy.  All support vanished.
7.   I made the most stupid mistake in my life – try to reproduce the pulse wheel with my limited resources.
8.   We compromised and developed a few versions of the Tong Wheel.  The third version showed signs of overunity and we demonstrated it at the Convention Center in Hong Kong. The details are in the thread titled – The Lee-Tseung Lead-out theory"
9.   The biggest compromise was the use of the proximity switch to do the ON and OFF of the DC current.  The theoretical correct way is to detect the position to turn ON and detect the position to turn OFF.
10.   In experiments, sometimes it relies on the experience of the implementer.  Mr. Tong was familiar with the proximity switch and was able to get some results.  We knew that it was not the best but we were eager to show something so that we could get more support.  The pulsing was far from optimal.  However, the demonstration was successful.  We got orders for the Tong Wheel and got some funding support.
11.   I decided to go for flux change systems with no moving parts.  I used the joule thief technique and used a cheap oscilloscope.  That gave the wrong impression of overunity.  Much time was wasted.
12.   I finally learned the lesson – I am not an experimental scientists.  I do not have the resources to build a team to do proper experiments.
13.   Divine help came again last year when I re-examined the Milkovic 2SO (this thread).  The development led to the Chan Wheel and the flying saucer.
14.   Looking back, I was right in 2006 when explaining the lead-out energy theory.  The 225 HP Pulse Motor was real.  It became a top secret of both USA and China.  I was lucky to be exposed to it because the traditional scientists at that time did not have an explanation.
15.   Is it the Divine Will that all Humans will benefit from this lead-out energy flying saucer technology?
Lawrence
Reply 3156
Pirate88179
Quote from: ltseung888 on May 25, 2015, 05:30:51 PM
Lawrence
Reply 3156
I rest my case.
(Note:  For brevity, the above quotes are quoted only in part.)
ltseung888
In 2006, available to Tsinghua University were:
1. 188 HP Laing car
2. Wang Shen He permanent magnet motor
3. Energy Multiplier
They were trying to explain the source of "mysterious" energy.
We just said that - when we push a pendulum horizontally, the tension in the string will increase.  That will lead-out gravitational energy.  That is a possible scientific explanation.  If we can lead-out gravitational energy, we can lead-out electromagnetic energy.
We then applied the explanation to the Laing car, the Wang generator and the Energy Multiplier.  We also did the same to the 225 HP Pulse motor.
Lawrence
reply 3156
Pirate88179
Quote from: ltseung888 on May 26, 2015, 09:48:05 PM
1. 188 HP Laing car
Lawrence
reply 3156
Lawrence:
Gravity is a closed system...all energy is conserved.  There is nothing that can be lead out of gravity.
Surely you know this by now?
