ltseung888
Quote from: ltseung888 on May 24, 2015, 03:37:09 PM
In many of the pulse wheel designs (e.g. Tong, Bedini), the permanent magnets and the coils are set at some angle.  Such arrangements do not use the magnetic flux at the optimal.  However, with tuning, they can still show signs of overunity.
Magnetic flux is not stationary.  When another magnet is close or when there is motion, the magnetic flux will change.  It is almost impossible to analyze theoretically.  Much will rely on experiments to check the results.[b][/b]
The best example is the 225 HP Pulse Motor.
With the fifth design of the flying saucer in reply 3302, the magnetic flux may be used in a much more optimal fashion.  Thus it will provide both thrust and lead-out electromagnetic energy.  The electromagnetic energy is likely to be the electron cloud or electron motion energy already present in the magnetic materials.
Lawrence
reply 3156
Look at the diagram in reply 3321 again.
If I remember correctly, the 225 HP Pulse Motor had 9 wheels jointed together.  But a single one could only generate 5 HP.  (That was supposed to be the prototype to be shipped to Tsinghua University).
Jointing nine 5HP wheels should only provide 45HP.  But the result was 225 HP.  This means that there are something we do not know about the magnetic or electromagnetic field.
The 225 HP Pulse Motor is an overunity device.    It is top secret.  But the flying saucer is also top secret.  If we can solve the technical problems of the flying saucer, can we solve the 225 HP Pulse Motor?
Divine Wine flows.  Lead-out Energy Flying Saucer is likely to be the UFO now popping all over.
ltseung888
I am consolidating the Tsinghua University QMOGEN and the Flying Saucer information in one file for easier reference.
A  The Tsinghua University Energy Multiplier Platform Experiment
References:
1.   Reply 3028 at overunity.com, Milkovic 2SO thread.
Experimental procedure
http://www.overunity.com/1763/12-times-more-output-than-input-dual-mechanical-oscillation-system/msg443538/#msg443538
2.   Reply 2994
Experiment 13 configuration suggestion
http://www.overunity.com/1763/12-times-more-output-than-input-dual-mechanical-oscillation-system/msg443378/#msg443378
3.   Reply 2981
Oscillating element rather than simple Unbalancing
http://www.overunity.com/1763/12-times-more-output-than-input-dual-mechanical-oscillation-system/msg443220/#msg443220
4.   Reply 2960
First attempt on estimating the material cost (less than HKD3,000)
http://www.overunity.com/1763/12-times-more-output-than-input-dual-mechanical-oscillation-system/msg442824/#msg442824
5.   Reply 2941
Technical Presentation to Bright Students
http://www.overunity.com/1763/12-times-more-output-than-input-dual-mechanical-oscillation-system/msg442464/#msg442464
6.   Reply 2943
Last attempt in the explanation of lead-out energy
http://www.overunity.com/1763/12-times-more-output-than-input-dual-mechanical-oscillation-system/msg442470/#msg442470
7.   Reply 2953
Presentation in Chinese
http://www.overunity.com/1763/12-times-more-output-than-input-dual-mechanical-oscillation-system/msg442672/#msg442672
8.   Reply 2870
Explain reply 2826
http://www.overunity.com/1763/12-times-more-output-than-input-dual-mechanical-oscillation-system/msg441896/#msg441896
9.   Reply 2826
Milkovic 2SO is a lead-out Energy Device
http://www.overunity.com/1763/12-times-more-output-than-input-dual-mechanical-oscillation-system/msg441078/#msg441078
B.  The Flying Saucer Information
1.  reply 3045
Theory of the Flying Saucer introduction
http://www.overunity.com/1763/12-times-more-output-than-input-dual-mechanical-oscillation-system/msg443810/#msg443810
A simple mechanism is shown in reply 3065
http://www.overunity.com/1763/12-times-more-output-than-input-dual-mechanical-oscillation-system/msg444284/#msg444284
2.  reply 3092
Theory of the Flying Saucer completed
http://www.overunity.com/1763/12-times-more-output-than-input-dual-mechanical-oscillation-system/msg444780/#msg444780
3. reply 3094
Divine purpose of my knowledge?
http://www.overunity.com/1763/12-times-more-output-than-input-dual-mechanical-oscillation-system/msg444810/#msg444810
4.  reply 3113
No need to eject material into space
http://www.overunity.com/1763/12-times-more-output-than-input-dual-mechanical-oscillation-system/msg445088/#msg445088
5. reply 3102
Leading out magnetic or electromagnetic energy
http://www.overunity.com/1763/12-times-more-output-than-input-dual-mechanical-oscillation-system/msg445265/#msg445265
6. reply 3302
Fifth design of the Flying Saucer
http://overunity.com/1763/12-times-more-output-than-input-dual-mechanical-oscillation-system/msg450886/#msg450886
7. reply 3123
Predictions
http://www.overunity.com/1763/12-times-more-output-than-input-dual-mechanical-oscillation-system/msg445278/#msg445278
8. reply 3352
ON/OFF control thoughts
http://overunity.com/1763/12-times-more-output-than-input-dual-mechanical-oscillation-system/msg452087/#msg452087
This post will be updated as necessary.  It will help the new comer to focus on the appropriate technical information.
Lawrence Tseung
reply 3354
ltseung888
Eighth Design of the Flying Saucer Engine.
Use Magnetic Repulsion.
Is it within the capability of the top Chinese or USA Engineers???
The two presentation files have been updated and attached.
Lawrence
reply3354
ltseung888
Prayer: "What should be the right thing to do?"
Guidance: "Serve the Divine Wine!"
Prayer: "Should I continue posting in this and other Internet Forms?  Should I share with friends and relatives?  Should I share it with strangers?  Should I use the News Media?  Should I approach the Academic Institutions?  Should I approach the Venture Capitalists?  Should I inform the various governments?"
Guidance: "What is your worry?  You have the Divine Wine.  Nobody have proposed the eighth design of the flying saucer yet?  It is absolute scientific certainty.  USA and Chinese Military Institutions must have built it or similar.  They keep it as top secret.  Their goal is to benefit their own Nation first.  What is your goal?"
Prayer: "Thank you for the Guidance."
The UFO believers will...
https://www.youtube.com/watch?v=58kLVo1AJuE
Lawrence
Reply 3354 3355
markdansie
Hi Lawrence
I hope you are well.
I travel to HK every month and China at least twice a year.
Do you have any technology or know of any that can demonstrate even one watt of free or excess energy?
I am happy to meet up with anyone or you to see such a demonstration even under an NDA
I remember once talking to you on Skype from the USA where you wanted me to see a technology you claimed was overunity, unfortunately it was not. I was under NDA which I respect so I can not discuss why.
Mark
