DreamThinkBuild
Hi Lawrence,
The forces aren't imaginary as long as you stay away from the term centrifugal. :)
Mark II Slingatron Test Launch of 1/2 Pound Payload
https://www.youtube.com/watch?v=snYAbkGWyzQ
Portable Mini Slingatron
https://www.youtube.com/watch?v=GXKb75boOMg
For power generation replace ball bearing with neo sphere and direct it through a plastic pipe wrapped with coils into cap bank. At the end have a copper pipe to slow the neo sphere down with eddy currents.
Edit: Image source: Slingatron - A Mechanical Hypervelocity Mass Accelerator by Derek a Tidman
MarkE
Quote from: DreamThinkBuild on June 10, 2015, 11:48:35 PM
Hi Lawrence,
Note that in order to convey force into the sling, the person swinging it must also exert force against the ground that person stands upon.  Absent some much larger mass to work against, then the person counter rotates versus the slung mass preserving the angular momentum of the system.  The person can only change their own momentum by changing the mass of their local system.  If they eject mass, then we call such a machine a rocket, and we call the ejected material rocket propellant.  Lawrence's idea literally has not got a leg to stand on.
ltseung888
Hi Lawrence,
Let us use the term "force due to circular motion".  We can still use the term CF to denote the force...
We can say that the flying saucer can be powered by the difference in CF force due to difference in angular velocity at the top and bottom part of the rotation.
MarkE
Quote from: ltseung888 on June 11, 2015, 04:50:59 AM
You can say such things and you will be wrong.  You cannot beat First Principles.
Paul-R
this seems an annoying way to calculate the energies.
Why not point the thing vertically upwards and observe the height the ball reaches.
Energy in = motor's voltage x current and time.
Energy out =  Mass . G . Height
(You could do it by measuring velocity and K.E. but that is trickier)
