Merg
New video of Veljko Milkovic!
Oscillations more efficient than rotations
https://www.youtube.com/watch?v=qktY1hDrRl8
(English & German subtitles available)
ltseung888
Some projects funded by Hong Kong Government.
Mr. Peter Chan said that he was associated with a project funded by the Hong Kong Government around 20 million dollars.  A quick check showed that many projects did get such and higher funding.
With good scientific results and the right contacts, funding for the lead-out energy flying saucer project is not out of the question.
http://www.itf.gov.hk/l-eng/Prj_SearchResult.asp
Lawrence
http://overunity.com/15077/ufo-propu-engine-closed-loop/15/#.Vax_t7tRFjo
ltseung888
Material list for the draft experiment on Vertical tube magnet repulsion.
1.   Vertical transparent tube 30mm inside diameter, 1 meter, HK$65, Sun International Supplies Limited 2780-0858
2.   Round circular magnet with hole in middle diameter 28mm, Six at HK$18 each, Wah Fai 9753-3792
3.   One coil wire 1mm diameter, 100 meters, HK$80, Wing Hong Electrical Supplier 2625-4736
4.   One ohm resistor up to 10 watts, Two at HK$6 each, Crocodile Clips etc. at HK$18, Bozam Radio Service 2388-9859
5.   On and off switch up to 10 Amp, HK$31, Ban Wah Control Equipment Co. Ltd. 2770-0800
6.   10 meters Magnet Wire, 2 soft ferrite rods 10 cm long, one diameter 30mm, one diameter 35mm, HK$100 Wai Choi 2388-3839
An Atten Oscilloscope and a DC Power Supply up to 30V were available from previous purchases.  Estimated cost HK$3,000.
Total cost = HK$3414
The cost including travel, small tools etc. should be less than HK$3,500.
Lawrence
zoelra
I do not agree with Milkovic's blanket statement that oscillatory motion is better than rotation.  It all depends on the bearing friction.  See the YouTube examples below.  If lightweight wheels (with little inertia) can spin for minutes, think what would happen if the wheels were larger and more massive (still using the same bearings).  The inertia, or moment of inertia, would keep the wheels spinning even longer.  I have found this in my own work.  If you have not tried using skateboard bearings in your own builds, I suggest trying them.  You can gang several together for a wider footprint if necessary.  Keep in mind though, not all bearings are equal.  The best bearings provide much lower friction and spin times.  They can also support significant amounts of weight.  The only drawback is the axle diameter, but as I mentioned, ganging them together, and placing the supports close to the wheel will reduce or eliminate any axle bend, especially when using hardened steel rods for the axle.
https://www.youtube.com/watch?v=1S12WbRrZeA
https://www.youtube.com/watch?v=zHGoidlKekA
SoManyWires
Quote from: ltseung888 on July 13, 2015, 05:35:58 PM
The reason why his name was not well known is that he still believed in the Military tradition - follow the party line.  He was responsible in arranging the Tsinghua University visit.  Technically that was a big success.
But when some Communist Party Officials interfered, Lee stepped back.  Lawrence Tseung stupidly used his own retirement expenses to try to reproduce the working prototypes, energy and resources were wasted.
The right approach is being taken now.  Just promote and sow seeds.  The mathematics is and will never be wrong.  King David killed Goliath with the circular motion force of the sling.  Let others with the equipment and resources shine.  Ignore the debunkers and the jeers.
China and USA will be forced to disclose their top secrets.  UFO or lead-out Energy Flying Saucer  technology will come out to benefit the World.
Lee Cheung Kin will not be forgotten in the scientific world.
Lawrence
http://overunity.com/15077/ufo-propu-engine-closed-loop/#.VZ0eCulRFjo
Sorry for your loss. He was of great inspiration to you, someone who really made you think. Someone who wanted a better world.
It is important that you continue in your efforts!
Thankyou for being so unselfish, and for helping shape the future with your research and experiments.
Lawrence rules! =)
Lee Cheung Kin will not be forgotten.
