norman6538
I propose the following simple test to demonstrate the real input and output power of the Milkovic ideas.
1. drive the setup with a weight on a string wrapped around a wheel or dowel
    to turn and set into motion the swinging.
2. then a similar weight wrapped on a string can measure the lifted output
   work.
Then if there is more output work than input Milkovic has the magic device we
all desire.
I have tried this on some setups and it has failed to produce more output
than input.
So my simple challenge is do your own test and post the results back here.
Norman
Russ Lee
 Years ago I sent him a description of a linkage that would loop the energy back to the pendulum to provide the overunity he claims this mechanism has. His response was that he was no longer looking for a "linkage solution".? He knows this is not an overunity device and is just letting this thing continue on regardless. It if produced 12 times the energy it needs to function, it would be a small thing to loop the energy back, even with 50% loss, there is still energy left over.
Quote from: djancak on November 30, 2006, 10:32:50 PM
i just watched the video.  ;D
this is a very fascinating yet simple machine. he demonstrates it's ease of use to do a powerful amount of work several times.
however, he does NOT show the device powering itself, which is the best way to demonstrate overunity.
List
Please guys, let's go back to more competent or at least relevant scientists and researchers.
List
Quote from: Merg on October 09, 2015, 12:04:58 PM
A video from the 2015 Energy Science & Technology Conference (USA)
by Aaron Murakami
Veljko Milkovic - 2 Stage Mechanical Oscillator
https://www.youtube.com/watch?v=kbQjaTZEPjI
It is really interesting that someone relevant in this field takes a stand on the matter without hiding in anonimity.
I truly hope this encourages other forum members to provide more material like this about relevant authors discussing significant findings, such as Milcovic's.
Grk
I agree on this. People are so brave when they criticize someone else's work.
It's not a small thing to you speak your mind and to stand behind your words - on internet and in real life.
I came across this paper published in Asian Journal of Science and Technology published by Nikhade, G. R et al. http://www.veljkomilkovic.com/Docs/G.R.Nikhade_R.U.Patil_S.P.Bansal_Two-stage_oscillator_mechanism_for_operating_a_reciprocating%20pump.pdf. It is really worth reading.
