0 Members and 41 Guests are viewing this topic.
Merg
New papers from India:
Microcontroller Based Performance Study Platform For Two Stage Mechanical Oscillator
http://www.ijmetmr.com/oloctober2014/smeghashyamreddy-sakjilani-32.pdf
Design and Fabrication of Hand Water Pump Operated By a Pendulum
http://ijesta.com/upcomingissue/11.04.2016.pdf
Low-Q
Quote from: Merg on June 19, 2016, 06:20:46 PM
Pendulum Operated Water Pump
by MSAJCE - Top Engineering College in Chennai, India
Project Demo by Students from Department of Mechanical Engineering, MSAJCE
https://www.youtube.com/watch?v=Xt4dLsqX_I4
If you calculate the energy of the waterflow. Let's say you pump 1dl water per second from the bucket. Let's say there is 30cm from the waterlevel in the bucket to the water outlet. That is approx 1N*0,3m=0,3 J/s (Or 0,3 Watt).
The inertia of the water will counteract the pendulum with the exact amout of energy that you get from the water flow itself.
This is basic physics.
However, the pendulum mechanism is a more efficient way to pump water by hand. Because the body consumes energy also when you act static pressure with your arm to the traditional lever. And you get tired sooner. Its like the difference between cycling and walking. You can travel the same distance, but you get less tired when using the bicycle instead of walking. Is a bicycle over unity? No, but you spend energy to get in motion, and after that you will travel with little resistance. When walking, you do not continue moving after your first step. You need to take another step, then the next etc.
If you use an electric motor to do the same job, the power consumtion would be the same with the pendulum method and the traditional lever method.
kratkaforma
Quote from: Merg on September 21, 2016, 02:36:19 PM
Pendulum-Gravity Motor in India
https://www.youtube.com/watch?v=2QrMoH6yfY0
yes, it is REALLY obvious that is Milkovic's pendulum oscillator and it REALLY seems they closed the loop!
my congratulations for all project participants!
