0 Members and 64 Guests are viewing this topic.
prajna
Not quite, FE.  Certainly logic will be required (although I am testing a purely mechanical system at the moment that may work).  You see the counterweight spins and the pendulum swings. When the counterweight is spinning clockwise the pendulum will sometimes be assisting that spin and sometimes countering it.  The secret is to lock the pendulum to the counterweight whenever its momentum would assist the counterweight and to let it swing freely whenever its momentum would counter the spin.  I initlially thought that would require quite complex predictive logic that would need to effectively model the physics of the system but it turns out that by not being quite so greedy for getting the maximum out of the system we can simplify the logic to an almost trivial problem: we latch whenever the pendulum is to the right of the main axle and moving at the same speed as the counterweight and we unlatch when the pendulum reaches the bottom of its swing.  Actually, we can use more logic and optimise the energy increase but we should be able to tap enough energy with even this simple logic to get overunity.
By the way, can we continue this discussion in the Jhula thread.  It just saves people from having to wade through all the Mikovic stuff to read about Jhula and likewise it doesn't fill up this thread for those who are more interested in Mikovic.  Thanks.
Bruce_TPU
Greetings friends!
I have enjoyed reading your posts for some time, both on this thread and others.  I have been working on HHO production for several months by combining patents.  BUT this lever pendulum idea has intriqued me.
Here is a drawing of a simple, efficient, mechanical way to close the loop between the lever and pendulum.  If you do not like this idea, I had one more, using the lever to build pressure in a tank via a pump (psi) and then like hydraulics, using that to re swing the pendulum.  I think this drawing is the simplest and can be scaled down to desk size or so.  It need not take up the whole garage..LOL!
Thank all of you for your tenacity, and creativity.
"With God all things are possible!"
BT
magnetman12003
Hi,
Check this idea out. A lot more is posted in the "Working Smot ramp from Tom Ferko"  in this same overunity group.  Its my last posting with illustration of how two magnetic pendulums might be used to power a self runner device.
I thank "Sam" for pointing me to this group.
A runner ring magnet travels the balance beam between both pendulum mounted ring magnets.  Only repel or bounce mode is used.  The illustrated blocks keep both end ring magnets from possibly slamming the articulating balance beam ??   Might not even need them??
Tom
magnetman12003
magnetman12003
Hi All,
Check this possibility out also. The weight of the ? pendulum would have to be adjusted to have this work.    Both fixed magnets and the balance beam runner magnet all repell each other.
Tom
