Merg
Pendulum Operated Water Pump | Mechanical Mini project
https://www.youtube.com/watch?v=OnLbKBr38SU
One important feature of a pump with a pendulum is that the work is alleviated or in simple terms it makes work rather easier when is compared with a traditional hand water pump. It is due to this underlined feature which enables the pendulum pump to be used as an efficient mode in the irrigation of smaller lots, water-wells and can also be used in extinguishing fires even by old people and children. By the use of pendulum based water pumping system we can increase the efficiency of the plant and reduce the effort, cost of production, production time, manpower requirement.
Working Principle
The oscillation of pendulum has dynamic action of forces. When pendulum is at the extreme ends, the component of force acting on the lever due to pendulum is minimum level and lever is at extreme high position on pendulum side due to action of counter weights. While, when the pendulum is in motion & is at middle position, the force due to pendulum is maximum level & lever is at extreme low position as forces exceed that of the counter weights. Repetition of this phenomenon is the principle of working of the project.
Oscillation of the pendulum is the input to the model. These oscillations will cause the lever to oscillate about its pivot point. The other end of lever as connected to the rod of the pump; causes it to reciprocate thus giving the pumping action.
Merg
Group no 05 2018 19 Pendulam Operated Pump
https://www.youtube.com/watch?v=ZyvA_8BFCW0
pendulum pump
https://www.youtube.com/watch?v=YxeKH1QjoMU
Pendulum operated water pump_mechanical projects
https://www.youtube.com/watch?v=46YpZGdavTA
Pendulum based water pumping system / Pendulum Operated Water Pump / pendulum hand water pump
https://www.youtube.com/watch?v=mzeOhJL_uTg
Milkovic Pendlum at Santa's Workshop
https://www.youtube.com/watch?v=03Ts5lTGNic
burnit0017
