iacob alex
  Hi Merg !
Thank you for posting this address . It's a new manner to play the oscillatory fulcrum ...if we take into consideration the so old shadoof cocept.
The same topic , at :  https://www.besslerwheel.com/forum/viewtopic.php?t=8238
   Al_ex
Turbo
Quote from: iacob alex on November 23, 2019, 10:12:19 AM
  Hi Merg !
   Al_ex
Jacob Alex you have to extract the energy from Gravitational acceleration this is 9.80665 m/s2 or approximately 32.17405 ft/s2.
Fixed armature pendulum and wheel kills this acceleration effect because it is a fixed point just like rolling a ball over a flat roof it will move or roll sideways but over the same level and it will not accelerate like it does when you would drop it.
There in you can find the secret.
All of these systems that use a center bolt kill the Gravitational acceleration by suppressing the distance traveled in the vertical plane.
When the mobile weights are above the center bolt you have a push on the center bolt and when the mobile weight is below the center bolt you have a pull on the center bolt, now in both states, the acceleration is in the same direction, but because the center bolt is fixed this potential is suppressed and will stay at the same level nullifying the conversion of potential energy into kinetic acceleration.
sm0ky2
If you scroll back to the first 40 pages or so,.....
We did the math for an pendulum with a secondary fulcrum.
Yes, at bottom dead center, the force vector is perpendicular along the shaft.
And yes, with a small enough counter-weight, a secondary fulcrum can be activated
by this force.
But at no point in the operation of the system, is the mass in motion not its' momentum
considered "overunity", or even close to the input energy.
Each activation of the secondary fulcrum decreases momentum of the pendulum.
A simple flywheel is 3-4x more efficient
