0 Members and 39 Guests are viewing this topic.
kratkaforma
Veljko Milković, an academic and inventor from Novi Sad, has done something great that has not been done by any Serbian inventor before. Milković invention of the mechanical oscillator is widely used worldwide, a testament to the fact that over 500 foreign companies use, sell and manufacture pendulum-based machines used in the heavy industry. The purpose of the two-stage meganic oscillator is multifaceted, because the character of the machine (two-arm lever with pendulum) allows its use as a press, water pumps, compressor, crusher, power generator, mini power plants.
https://buchner-express.nl/6198/01/
https://www.elanguage.pl/12/18303/series-trapezium-mill/
https://www.madeira-diving.de/screen/615-Jan.html
https://www.exaltosport.nl/12338/7vyDw1
https://wynajem-jachtu.pl/z5js5o/3644.html
https://www.vente-fermetures-colmar.fr/14_30850/
https://citytowerhotelbhb.store/2021_03_04+38572.html
https://www.fotopalast.ch/data5/20341_2020-09-25
https://antrening.pl/9039/sitemap.xml
https://eratuszowa.pl/data4/6215/lvkf.html
kolbacict
Quote from: i_ron on April 05, 2007, 11:12:57 AM
By the output side I mean the longer side opposite the pendulum. Is the device more efficient if more weight is added to this side, or is that detrimental?
For those who are testing this device, remember: the potential energy input into the pendulum (in joules) is found by the formula mgh m=mass of pendulum (in kg) g=9.8 m/s h=height in meters that the center of mass of the pendulum is raised.
Although Milkovic's flashlight experiment was somewhat helpful, the part where he showed that the flashlight used for the input powered 9 others was unconvincing. He obviously input more energy then required to light the one flashlight on each stroke because his hand+the flashlight had kinetic energy when it struck the pendulum.
Not so. His hand + the flashlight was not in contact with the pendulum, only
the sprung lever actually makes contact.
The secondary lever is akin to a teeter totter. two boys of equal weight at an
equal distance make it go with a modest kick off of one pair of legs.
One fat man and one small boy can still teeter totter if you adjust the fulcrum.
If you add too much weight to the output side in a Veljko device the pendulum will
not lift it.
The output side of the secondary arm has two strokes, an up and a down.
Think of it this way if you wish... the pendulum, on it's down stroke, lifts the
counter weight. Gravity lowers the counter weight on the pendulum's up stroke.
You can extract this resulting force equally on both strokes, or bias it to favor one
or the other stroke.
Ron
Why in the beginning there was such a lively discussion, but now everything has disappeared into oblivion?
kolbacict
kratkaforma
https://tesarstvismolik.cz/kenya/2020_Jul_19450.html
https://speedcourier.be/2020-Jul-17_30398.html
https://casablancadelsol.com.mx/Bxin/12_libya-gypsum-trapezium-mill-supplie-3986690830.html
https://www.ravelslow.pl/Miningproductionline/bPz9V1_38671/
https://wodzislawnoclegi.pl/ballmill/10393/1492470280.html
http://sigmatychy.pl/01_Jan_2006_955.html
https://zakladszkolenia.com.pl/Nov-Mon-4718/Specifications-For-Hammer-Crushers-In-Pdf.php
https://www.fourmat-band.de/en1/744/tsc1xb1o.html
https://www.voedselbanknoordwijkerhout.nl/data3/1575471934-pendulum-magnet-for-crusher/104/
https://keku.cz/data7/1970-01-01-Thu-How-Mtw-European-Trapezium-Grinding-Mill-Works--2020/5212/
https://www.al-capone.cz/7713/dWEkb/2019-12-30/
https://www.nobodyhome.nl/basic_rockcrushing_theory_13700.html
https://kamasolutions.pl/19756/indonesia/1519020122.html
https://www.magnaalu.pl/8775/LfQiw1
https://normaserveert.nl/10982/86Uwz2.html
https://www.riverband.be/18684/2018-Jul/Vg4Gy1
https://podhalanskialarmsmogowy.pl/724/MEsTd0_04/
https://www.josephvadakkel.pl/16806/2kNS61.html
kratkaforma
https://www.speciaalcentraal.nl/ore/2020-12-1451/
https://www.internationales-zaubertheater.eu/gypsum/Sep-2743/
https://visartmedia.pl/jawstone/39846.html
https://www.robertbatstra.nl/crusher/2021/0318/11553.html
https://minstalacje.pl/granite/Sep-mtw-mill-trapezium-cost-australia-4569/
https://zooforum.pl/Sreen/complex_pendulum_crusher_assembly_drawing_2197.html
https://i-podroze.pl/Feb-13_24757.html
https://www.dansite21.fr/data11/2020-12-2309/
https://www.lowkeywebdesign.nl/jawcrusher/14942-2020.html
https://www.collectif-jacquerie.fr/type/21_81/2653.html
https://dietabudwigowa.pl/data11/6K4el2/2020-06-14.html
https://www.elanguage.pl/02/8394/of-mtw-mills/
https://www.bockelmann-coaching.de/mill/17690.html
https://pflanzplanerin.ch/f/2020-09-25-Fri-Libya-Gypsum-Trapezium-Mill-%C3%8F-2020/5834/
https://rzedszkole44.pl/sand/20_Jul_1977/
https://kormoran-kolonie.pl/crusher/2020_Oct_Sat_1710/
https://kerkingenk.be/crusher/16540.html
https://www.uwiolilodz.pl/93/jGuyw0/YY.html
https://galeriedusauvage.ch/jaw/2020-11-26-Thu-mtw-trapezium-mill-price-2020/5258/
https://www.custombikemotorcycles.pl/agg/Jul-4968/
https://www.dzunglertenek.cz/12331/furnace/.html
https://pojistenadomacnost.cz/2018+Feb+21/X4cEr.html
https://www.wiadomosciasp.pl/hammer/12945.html
https://www.senterre-e.be/Feb/25-18865.html
https://kreatywnydzieciak.pl/kenya/677/
https://www.sprozyca.pl/coal/2020-10-316-how-is-a-MTW-grinding-mill-cost.html
https://www.fotobobas.pl/20135/fine.html
https://dobryfotobank.pl/crusher/4378.html
https://www.radiobremen-werbung.de/malaysia/grinding-mill/d2s6mg.html
