0 Members and 27 Guests are viewing this topic.
seychelles
YEAH, I AM STILL ALIVE AND STILL LOUD. THIS UTUBE WILL HELP UNDERSTAND
THE EXTRACTION OF EXCESS POWER FROM AN INVERTED PENDULUM.
MY SUGGESTION IS THAT THE PENDULUM SHOULD BE CONNECTED TO A SPRINGY
METAL CONNECTION.
https://www.youtube.com/watch?v=6fslf98aw7E
Floor
Good to see you are still exploring  Seychelles.
Nice demo by ray.
Each wheel does one full rotation.
Total rotated distance for each wheel is the same at the end.
          but
First the wheel on the right rotates farther than the one on the left,
then the wheel on the left rotates farther than the one on the right.
The energy present is the same in both wheels, once a complete
cycle has occurred.
kolbacict
https://youtu.be/nD3_3DZ7qFo
On the right, the load is heavier, but while the pendulum is swinging, it rises up!
With pulleys and ropes, did you come up with it yourself? It never crossed my mind ... :)
Is it patented?
p.s.It turns out that a double Milkovich pendulum with two pulleys can be replaced with a simple rope on two blocks?  And will it perform the same function?
Floor
I thought it up. I thought it would be a simplifying of the Milkovic device.
I don't know if it was ever pateneted.
With some kind of ratchet on the cable it could be used for lifting.
Without a ratchet it could be used as part of a pump or hammer.
seychelles
PURE GENIUS FLOOR. PITY YOU ARE A BIDEN SUPPORTER. ;D.
THAT WILL BE IDEAL IN A POOR COUNTRY FOR A GRAVITY LAMP.
RACHET IS REQUIRED THOUGH.
