sm0ky2
Why is this manual pump jack still a thing?
Go back to the teeter totter, put the fat kid across from you again
But this time hang a pendulum under your seat:
Does this change your situation?
NO!
http://www.phys.unsw.edu.au/~jw/blocks.html
sm0ky2
Cloxxki
Yeah, but but but...if I misunderstand how forces relate to work done and power...just hanging a pendulum from that thing makes it a free energy device that will save the planettttt!
Years and years of building and no-one manages to extract the tiniest bit of energy without reducing the first stage amplitude.
Let's all come to a compromise. Half of the great minds now pursuing the two-stage oscillator will move on to other ventures nothing to do with it, and half will never stop working on it, unless they want to stop.
sm0ky2
In most parts of this field i admire persistence,
And throughout history, scientists have been proven wrong
Or their theories inaccurate or incomplete.
Two however, have survived the test of time.
Hermes and Archimedes
i, myself, wouldnt challenge a word either of them said.
In fact, if any part of science defies a single one of either of their principles,
It is probably incorrect.
sm0ky2
Quote from: kratkaforma on April 07, 2023, 04:48:37 AM
https://www.aparat.com/v/eWZa3?fbclid=IwAR2q2UOz3YgxG48GXYbWI46_l5Y-8gVn01ldxFnEQkonB48dZge8_XX02Ag
it does the same thing, irrespective of proportional leverage, or weight imbalances.
We can multiply or divide by the leverage proportion, but the mechanical gain comes at a proportional cost.
Fix only a pendulum,
Constrain its swing to a single plane along the horizontal as would a clock
And place a stiff spring between the shaft and pendulum.
get another pendulum as the same as you can, with no spring
but the length adjusted to match the other for timing.
(here we ignore the elongation of spring for discussion)
Now start them from 90-degrees to the vertical.
This demonstrates the work function of the spring, almost precisely
as observed by the decrease in momentum of the pendulum.
The "waterpump" will work exactly the same connected to the shaft OR the end of a Lever.
this makes no difference. The mechanical leverage only increases the work function.
As you see in every model or experiment, this slows the pendulum.
E=mgh
