Cloxxki
Quote from: thx4 on July 19, 2023, 05:08:21 AM
https://youtu.be/xb6IM-wVP_s
Il y a bien une amplification mais c'est la cinétique de la roue qui est transmise au balancier, par désynchronisation avec le ressort qui maintien la masselotte bleue.
Why not take the 10 second and translate it to English which everyone on here speaks?
Does that wheel not slow down less without the attached vertically dangling items attached? The attachment move around, but don't really accumulate meaningful net kinetic energy. The wheel's initial kinetic energy gets sloshed around the complex system and it comes to a halt faster than  a normal wheel, probably. And even if it turn a big longer, that would be from transferring high speed high drag into low drag kinetics early on and sending it back later. A simply flywheel would still vastly out perform this setup, right?
thx4
Sorry for the language my English is insufficient, usually I translate there it is an lapse of memory...
Concerning the video there is no question to ask it shows only what it says to show, the rest is pure speculation, no interest. Or do it yourself, I don't know what you're talking about!!!!
ramset
Google translate
There is indeed an amplification but it is the kinetics of the wheel which is transmitted to the balance, by desynchronization with the spring which maintains the blue weight.
End quote
Sir
It is truly a puzzle which needs investigation..
Others have written ( and explained in correspondence) the output of the pendulum is a bit autonomous of input ..?
Nice you add flywheel and dynamics ..and share your research!
Greatly appreciated...
Respectfully
Chet K
Thanks Grandma
Atti2
Quote from: ramset on July 20, 2023, 10:49:26 AM
Hi.
Not strictly related to the topic. I apologize for that. But we can see similarities. (?)
https://www.youtube.com/watch?v=rzgOjJVKxNc
https://www.youtube.com/watch?v=hyzJbB-OdpU
What is the process of amplification?
In this embodiment, magnetism is used.
It worked for more than 1 hour. Proof that magnets can be used as a source of energy if they are mounted in the right arrangement.
The beeping in the video footage proves that acceleration is happening.
Unfortunately, the process stopped because the steel balls fitted were magnetised.
That is why if you try to operate such systems in a way that the demagnetisation process is involved, there is a chance of a working machine.  Otherwise, no. A good example is the following test:   https://www.youtube.com/watch?v=SHbQXnXK6Xc
So if we find this phenomenon in the system, then we can move on. Whatever system it is.
Atti.
Mayo
Who is John Bedini? It is about a famous American inventor in the field of electrical engineering who also started another research over unity and free energy forum and the administrator himself gives a chance to our inventor as well as many researchers who make a combination of the Milković oscillator and Bedini's electrotechnical achievements.
https://www.youtube.com/watch?v=iXw8CccTEyk
https://www.youtube.com/watch?v=UVCvP53Au60&t=18s
https://www.youtube.com/watch?v=lVVVXJfGItI&t=21s
https://www.youtube.com/watch?v=qxTibOlHT4w
https://www.youtube.com/watch?v=s786CZkdoi0
The combination of Milković and Bedini can create a revolution in the world of science
