konduct
I have built a wooden replication of the device and it works just as it appears in the video.  I still need to re assemble the pendulum with a fixed hinge or bearing.  Just as the Serbian inventor said, an elliptical swing of the pendulum doesn't give the same amount of kinetic energy.  I have been thinking of methods of closing the loop...
It seems that it will take the least amount of energy to push the pendulum once every swing.
The power of the device is basically the difference in weight on either sided of the pendulum...
The "RPM" seems to be mostly related to the length of the pendulum.
The machine almost needs a work load to run...It runs better with resitance (up to max load) on both up and down strokes.
konduct
The "C" Clamp in the picture is to hold the vertical wooden plank on as a temporary "hammer" It also gave me a little extra weight.  The pvc pipe is filled with steel shot and the hanger in the picture is irrelevant.  The little black things toward the front are lead fishing weights coated in rubber.
hartiberlin
Konduct,
great !
Could you please try to couple aspring based thread ( ishing line
for example with a spring) to the pendulum weight and
pull with the line the pendulum and fix it via a roll
somehow to the hammer side and thus keep the device going and going ?
Will this never slow down ?
Many thanks.
