0 Members and 18 Guests are viewing this topic.
hartiberlin
Hi Hans and all,
I also played with it and I came up with a setup
that describes the Milkovic setup much better.
Have a look at the encoded video also.
Here are the files attached.
hansvonlieven
G'day Stefan,
As you probably know by now I do most of my work very early in the morning. I usually get up somewhere around 4 o'clock and work until mid-day. Then I do other things until I've had enough. It is 5:30 PM now and I have had a couple of beers and my thinking is not at its best anymore. I have downloaded your WM file and had a quick look at it.
It deserves serious study, not a quick reply. So please bear with me, I will give it due attention and let you know my thoughts on the matter when I am convinced I have seen it right.
Greetings from Australia to you and the old country
Hans von Lieven
@ adriano,
I am aware of the dilemma. Please look at page 37 post 552 this thread and at this : http://www.overunity.com/index.php?action=dlattach;topic=1763.0;attach=14178
Hans
abassign
@hansvonlieven
@Stefan
But it is so difficult that someone can build a replica of the invention of Milkovic and to make some appropriate measures ?
Ciao
Adriano
PulsedPower
Pmotion, the problem with your perpetual flow device is that the liquid head in the left hand pipe is greater than the head in the right hand pipe from the top to the siphon break (reservior discharge) The fluid will flow backward to what you are expecting and will come out of the lower RHS funnel until enough air is drawn into the system though the reservoir discharge to reduce the head on the LHS. The system may become unstable and oscillate dumping all the reservoir water but accepting none of it into the funnel. You should try it just to get a feel for a bit of fluid dynamics/statics
There was mention of hand pumps achieving 100M lift in this thread, sure by using a down the well pump with a long pump rod, a 100m lift is possible. There is nothing to indicate that the pump shown is a down the well pump it appears to have a bend in the pipe going into it's base in one shot. Down the well pumps are not very portable, needing to have the rod and casing assembled on site, in which case a practical suction limit would be 6M at sea level and it may be almost impossible to get it to prime at 6M if the piston seal isn't close to perfect.
allcanadian
@ hansvonlieven
I did not mean to imply you said this cannot be done, I meant that I have yet to convince myself that this cannot be done. I didn't mention one thing I found in my experiments you guys may find  very interesting. In the dual pendulum balance beam we could say the total mass and all forces revolve around the fulcrum, the fulcrum is the center of power, without it the system would collapse. In my experiment I found the fulcrum could be "moved" away from the center of balance when one end of the balance beam was within a range of 30 Degrees from level without expending work as the fulcrum is moving horizontally and is never in a condition of having to lift the beam to find its center. As well the fulcrum and the base are under the influence of the system as a whole when forces within the system change, I think this is what Milkovic is getting at, a large force acting over a small distance ---- work extracted at the perfect moment when it can have very little effect on the system.
