gurangax
why dont you guys use the device to compress air and use the air compression to run a gravity wheel. and from the gravity wheel use a bit output to oscillate the pendulum. It might just work like that.
-regards-
hansvonlieven
@ gurangax
What is a "Gravity Wheel"? Don't you mean a flywheel?
You can do all sorts of things with it, the sad fact is that there is not enough energy in the system to drive itself.
Hans von Lieven
helmut
Quote from: gurangax on February 27, 2008, 07:11:45 AM
-regards-
@gurangax
Why to go via air? Do you know the fuelles design of their Gravity engine?
Just have a look at it and than emagine to change the air zylinder against a milkovich device.
I have not testet yet.But i think it is worth to do so.
helmut
Scorpile
I haven't readen all th thread... an admin should left only "conclusive" comments on this thread.
I have to add my 2 cents... well i think i can.
For what i see, this system produces more energy in form of torque.
What we need to do is use a rotaing motor to rotate an unbalanced flywheel lets say, with 10kg on one end.  Let's start with the weight in the dead upper centre and apply current to the motor only to accelerate it enough (when going down only at the first 15 or 20 degrees i thnk) to complete the revolution and do it again.
Because of kinetic force involved in the rotation of the unbalanced flywheel, the motor should not need to be really powerfull, because we are starting rotation from dead upper centre, so the wieght itself gives the power to the system to complete the revolution when you add the acceleration.
Then measure how much power we use on every revolution (obviously watts).
Then maybe use the same "flashlight" generator he used to see if we can obtain more watts than used on the "unbalanced flywheel motor", and probably attach the flashlight generators to a capacitors, with a mechanical relay on the arm to sent the power from capacitor to the motor.
If this work then i'm the winner of the contest??? Because i live in Panama and my salary isn't enough for sustain my family, i have too many debts right now.
I think this is the simpliest way to make the close loop and will work but have not enough money to build it.  Should i close my mouth, because the calculations of other members shows that the device will not offer any OU?
eugene-g
Greetings!
I took the time to read all 43 pages of this discussion. Very interesting and promising.
I'm going to try and build this device, but I would like to break this process into multiple phases.
First, I want to find a way to sustain the amplitude of the pendulum motion without attaching it to the lever.
The two questions I have for this forum:
1 Would it make sense to use a low friction ball-bearing  as a pivot or is there a more efficient way
2 Is it worthwhile to experiment with using a permanent magnet add an additional pool to the bob when it is nearing the point zero-gravity
Look forward to your suggestions.
-Eugene
