0 Members and 38 Guests are viewing this topic.
Scorpile
How you plan to complete the close loop?  I belive the way i say is the most easy to do it, and because to make an unbalanced flywheel starting at dead upper center to complete a turn, you need only a small and not really powerfull motor.  You could use a heavy weight and a geared small motor.  That's why i think this system can work.
Scorpile
Ok... look at the model i did.
For me it's interesting that applying a force of 6.6N allows you to lift a mass of 50Kg.  And applying 6.6N only allows you to lift 0.673Kg.
Can this allows us to use a generator geared like the next one, and charge capacitors to generate the 6.6N of force to spin the flywheel?
Here is my model.
http://pabo.com.pa/joe/oscilation.wm2d
FreeEnergy
Quote from: Scorpile on March 03, 2008, 12:08:00 PM
Here is my model.
You need to turn on Air Resistance. Go to World>Air Resistance>Hight Speed
Scorpile
hansvonlieven
@ Scorpile
You are not moving 50 kg.
In a finely balanced system such as this it needs only a sparrows fart to tip the scales. All you are doing is disturbing an equilibrium, not doing any work.
Hans von Lieven
