hartiberlin
Hi All,
I can get now a 100 Kg weight lifted up about 1 Meter every revolution
with this new idea from user Scorpile.
I am posting here now the picture and will upload the movie and WM2D file I just made in the
Downloads area.
P.S: I am using the green 10 Newton Force vector( see  green arroy)
all the time on a 80 Kg yellow disc and at the 33 Kg additional weight,
which is attached at the yellow disc, so how do I calculate the used input energy ?
( The same works, when I am just using 10 Newtonmeters of torque onto the disc on its axis)
The 100 Kg weight lifted by 1 Meter is about Energy= 100 kg x 1 meter x 9,81= about 1000 Joules of energy per revolution.
But how much input energy is spent for this ?
( I am a bit tired right now to think more about it...)
This design can be surely still optimized with better leverage fulcrum arm length and
other weight combinations...
there is a lot of room for improvements...
Regards, Stefan.
hartiberlin
Okay, the movie and WM2D file
are now downloadable in this ZIP archive file from here:
http://www.overunity.com/index.php?action=tpmod;dl=get15
Regards, Stefan.
nightlife
I have messed with this thing for a couple of hours and it will not work without added force or attraction. You do get more power from the opposite end of the wheel but the out put of the excess power is not timed right to give the wheel the added power it needs to keep going.
It will take some altering. Some of the excess power from the opposite end of the wheel, will have to be used and then it might just work.
Something like a rear bike wheel freewheeling hub. With added pressure it engages but without pressure, it freewheels. The front wheel in this next picture would have a freewheel on both sides to accommodate both the down push and the up pull. Both the front and rear wheel may need to be the same size but I haven't thought ahead that far as of yet to say which would be best.
nightlife
Scratch the up pull thought. It will not help. But I would suggest keeping a freewheel on both sides just for balance of torque reasons. As a matter of fact, it may be best to put the freewheels on the rear wheel. I think I can modify a old bicycle to see how this concept works. I just happen to have a couple old bikes at the shop that no one has used in years.
I have what is needed to build this and if it does produce over unity, this build should be able to tell.
FreeEnergy
ok here you go again.
i have made minor modification to the system and turned on air resistance to high!
wow!
please see file attachment.
