FreeEnergy
(see my previous reply)
....and when you set it to low air resistance the thing seems to speed up!!!!!  :o
Low-Q
Many pages now, and I haven't read all of it. Anyway, this device is by my opinion the most interesting approach to OU. It should be an easy match to close that loop. Simply by using an electromagnet right under a swinging iron pendulum. The electromgnet is driven by the output via a simple generator - like these in batteryless flashlights. So the pendulum is activated synchronously to its swing frequency. Should be easy to make such device.
I think however, that hartiberlins thought about tapping gravitional force, should at the very end result in no gravitional field at all, and the pendulum will stop... Too long time to worry about that :D
Vidar
hartiberlin
Quote from: FreeEnergy on March 12, 2008, 04:27:11 AM
ok here you go again.
i have made minor modification to the system and turned on air resistance to high!
wow!
please see file attachment.
Well just changing the force from 10 Newton to 15 Newton then also works with high
air resistance, butas this is a low speed application air resistance will not play
any effect on it.
So how can we calculate best the input energy this way ?
hartiberlin
Quote from: nightlife on March 12, 2008, 01:16:05 AM
Scratch the up pull thought. It will not help. But I would suggest keeping a freewheel on both sides just for balance of torque reasons. As a matter of fact, it may be best to put the freewheels on the rear wheel. I think I can modify a old bicycle to see how this concept works. I just happen to have a couple old bikes at the shop that no one has used in years.
I have what is needed to build this and if it does produce over unity, this build should be able to tell.
@nightlife,
I think you have missed the principle, cause it is used to lift at the right side of the fulcrum
a 100 Kg weight for 1 Meter, but you tried to rotate something...
So instead of lifting a 100 Kg weight by 1 Meter is could be used to lift something else, which is heavy
or push a flywheel.
FreeEnergy
maybe for every revolution or two the weight locks at 12 o'clock then the system balances, then you unlock it from 12 o'clock and the whole thing starts over. know what i am saying?
