FreeEnergy
the only energy being used is to lock and unlock the weight at 12 o'clock which is very little.
hartiberlin
Does anybody know, how Gears work in WM2D ?
Are there any good video tutorials out there for WM2D ?
nightlife
hartiberlin, "@nightlife, I think you have missed the principle, cause it is used to lift at the right side of the fulcrum
a 100 Kg weight for 1 Meter, but you tried to rotate something...
So instead of lifting a 100 Kg weight by 1 Meter is could be used to lift something else, which is heavy
or push a flywheel."
If you take off the 100 kg, then the pull could be utilized too, but I think it would work better if the weight stayed and all the focus was put on the push because of the timing of the wheels most useful force. It starts to loose most of it's momentum at 9oclock and that?s when the weight is lifted. Then the weight drops at about 10oclock and that push is when the wheel needs it the most. You lose nothing from the added weight because it is utilized by the push by adding more power the push when the wheel needs it the most.
This would give the wheel more force when the wheels weight is fighting gravity. The wheel should speed up to a certain speed depending on the gears.
I will be building one using a ten speed rear bike wheel. I believe the crank I have is a three piece crank which will allow me to have equal pressure on both sides of the front sprocket.
I will attach a gear on the opposite side of the rear wheel to test the power achieved. If that gear can turn anything attached to it, the device would then be proven to be a over unity device.
Scorpile
What i think is to take off the weight, and add something to rotate a generator with gears, which needs the same force applied to make the generator rotate really fast, just like the kinetic lights the original inventor used.
