hartiberlin
Here is also another great physics simulation program
Newton lab:
http://de.youtube.com/watch?v=11rmKvT-R7U
http://www.dsmm.net/demos/demo_newton.php
Maybe we can simulate with this program it much better in 3D ?
Regards, Stefan.
hartiberlin
Quote from: FreeEnergy on March 12, 2008, 05:36:53 AM
the only energy being used is to lock and unlock the weight at 12 o'clock which is very little.
Hi You don?t need tolock  it,
it works by its own movements.
I just played with the concept now for a few hours,
but it is very hard to synchronize several discs, weights,
gears, etc...
Also I really need a good video tutorial how to use and setup gears
and ropes to pull things or move discs...
Can anybody provide a good video tutorial on youtube or
somewhere else about this topic ?
It all comes down to the right resonance frequencies or weight disc size-pendulum
swinging cycles...
very hard to synchronize it all.
If also somebody could teach me, how to use locks on springs
and how they could be released on purpose again,that would be really great.
So I need to compress a spring with a moving weight.
Then at a certain position of the spring and weight the lock
must apply and hold the position of the spring or connected weight
and then wait a dedicated time and then release the spring or attached weight again..
How could this be modelled in WM2D or NewtonLab ?
Many thanks.
Regards,Stefan.
Scorpile
Well.. i used MOI to give all a simple idea of the generator side.
astroshima
I have made some corrections to my previous post:
Quote from: astroshima on March 10, 2008, 09:15:36 PM
Here are these corrections:
"...PS: The "problem" with this construction is that the both ends of balance beam are the same length..."
"So I had coefficient of efficiency equals to 0.54 (54%)in this particular test with this particular device.
I made theoretical approximation for constant oscillation mode, based on previous test, of maximum coefficient of efficiency with my model,  and it was 0.9 (90%)"
"...I did this tests more than 5 years ago...(PS: at Dec. 17. 2002.)"
aleks
Quote from: Scorpile on March 12, 2008, 10:59:00 AM
You have to find someone with a 3D printer to test your ideas. :)
