0 Members and 43 Guests are viewing this topic.
astroshima
Quote from: Scorpile on March 12, 2008, 10:59:00 AM
Well.. i used MOI to give all a simple idea of the generator side.
Scorpile your idea is excellent! Thanks.
It is possible to use bike for all this (I mean for Milkovics model!)
Pedals could be balance beam and rear wheel could be used to lift weight (with rope) or to generate electricity with dynamo!
We can mount pendulum on one pedal and extra weight or ledge on other pedal.
So input work (on pendulum) could be measured with video camera and ruler by formula dA = m*g*dh.
And output work could be measured with unimer (on dynamo) or by formula dE = m*g*h if we lift the weight (m) with rope by rear wheel!
nightlife
 I built it today but found that the derailleur was taking to much energy away. The derailleur is necessary when the sprocket is attached to the stationary frame because it is used to control the chains slack. It will not work that way so I mounted the sprocket to the moving frame and I am doing away with the derailleur. I will now be using the pull instead of the push because that is the most powerful action this design has. After the wheel is steady turning, it does not take much power to keep it going. I did find that a load is a must to achieve a steady action. The faster it goes, the more erratic the motion gets. The load has to be pared with the RPM's to keep a steady motion.
I hope to have better results tomorrow with the alterations I have made. I have to buy another chain in the morning to add to the old one, to meet the new design spec's.
nightlife
I tried every way possible and I could not get it to power it's self. There is no over unity here with this design. I am done here and I am off to try another idea. Not sure which one as of yet but I am sure i will figure out before the night is over.
Good luck to those still playing with this threads concept.
FreeEnergy
look i am telling you guys to get free energy all you need is to pause/start the rotating weight after every revolution or so at 12 o'clock, then let the whole system balance, then after that let the weight loose again to repeat the process. the system provides more than enough energy to self lock/unlock from 12 o'clock.
just need simple circuit and some kind of mechanical locking-unlocking mechanism for the rotating weight.
nightlife
FreeEnergy, if that is true, then I should be able to put a weight on a bedini school girl pulse motor design and I should get a better end result then I did without it.
I will test it using two different coil designs. One with power wrapped with 24 gauge and the pickup wrapped with 22 gauge and the reversed.
That should be a fair way to test your theory. Do you agree?
