0 Members and 44 Guests are viewing this topic.
Kul_ash
I am also failing to understand Jovan's analysis of centrifugal work doing extra work. Isn't it the centripetal force that is responsible for circular movement of pendulum? If there is no centripetal force, then pendulum can not move in that motion. And isn't this centripetal force equal and opposite to centrifugal force as per Newtons law? Then how come centrifugal force is doing additional work?
Prophmaji
it is very simple to test. Make a basic set up that functions, use a large heavy wheel on the output side..and connect to the central bearing of the heavy wheel by the use of two ratchets, one on each side of the rotating wheel's bearing.  Connect to the vertical arm via springs, to the ratchets. This keeps the energy in the springs and releases it effectively to the rotating massive wheel.
Then pull power off the rotating wheel.
Of course..that experiment then brings other ideas to mind......
This device, is 'sound'.. it is an application of the fact that gravitation is a 'polarized-oriented-gradient'.
It is NOT equal in the vertical vs the horizontal orientation, with regards to energy given and taken, with respects to physical distances moved. This application takes advantage of that simple point.
This point, in combination with Bessler type massive wheels and magnets, can be used to move the steel balls around the wheel positions when the balls are nearly in the horizontal domain/position, to positions either closer in or further out for greater or less leverage. Far less energy is required to move the balls when they are horizontal. Static magnets positioned slightly away from the moving wheel can be used to force the balls about.
2b
Veljko Milkovic
all he has to do is use 2 big syringes and some tubing
to show "overunity" or "perpetual motion".  you just
connect the "needle end" of each syringe with tubing
(best to use as big of holes and tubing as possible),
fill one syringe and the tubing with water, and then
use the downward force of the dead weight to press on the
syringe full of water, and then use the force of the
empty syringe expanding (on the other end of the tubing)
to push the pendulum weight.  on the upward stroke of
the dead weight, the respective syringe refills itself.
2b
in other words ...
you need to use hydraulics to prove "over-unity" or "perpetual motion" with the Milkovic machine.  you might be able to improvise with 2 syringes, some tubing, & water.
hydraulics will also allow you to convert from a "small distance, large force" (the dead weight), to a "long distance, small force" (to push the oscillating weight).
