0 Members and 27 Guests are viewing this topic.
Talmin
It's now published a full paper by physicist Nebojsa Simin:
Original scientific paper - Free energy of the oscillating pendulum-lever system:
"...The effect of creating the free energy results from the difference between the work of the orbital damping forces of the lever and the work of the radial damping force of the pendulum motion. This effect enables increase of the input energy. The coefficient of efficiency of the machine can be more than one."
http://www.veljkomilkovic.com/Images/Nebojsa_Simin_paper_Free_Energy_of_the_oscillating_pendulum-lever_system.pdf
scorpion
Hi all
Here some pictures of my oscllateur Vilkovic,
weight of the pendulum 12 kg weight on the release lever is a spring, spring tension is adjustable to several positions with a lever that allows me to instruct its output by 14 kg to 25 kg, it is much simpler than setting a fixed weight, borne down much faster because there is almost no inertia, the load increases with the amount of leverage output.
The ensemble is constructed of wood and iron, rigid construction for the minimum vibration,
all this construction is set firmly on a chest filled with sand around 100kg, front ago weighing 50 kg over 4 feet, which improves stability,
and the rear is fixed to the wall of the building with the help of a clamp, cel? is perhaps an exaggeration, but not cel? there are too many shocks pests as the pendulum of 12 kg generates a lot of high-strength at the bottom and front to back
it would achieve much stronger if the pendulum would have a weight of 20 kg 30kg or 50 kg
see you
