Nabo00o
Naboo00, thanks for the thumbs up on my water pump.
I'm pleased you think the design is easy to build, it is, Grin - now that I have tinkered with it for over a year and pounded all the weak spots out of it by brute force experimentation.
I hope you enjoy the energy free water as much as we do.  I hooked it up again just 2 days ago now that the weather is warm enough and it looks like we are going to need it. No rain in our area for over 3 weeks and the ground is bone dry. Sad for April spring weather. I guess global warming is starting to bite us now for real.
Well it is, since even I could build that thing  ;D
Well, as I now have studied your setup some more I see that it does actually send a lot of water (maybe half) down to a lower potential, but the other part is traveling way beyond the hight of the original source, right?
So, theoretically, the water being shot out from the first valve controlling the frequency, it should almost reach the same hight as the source because of its pressure right? Well in that case we are only dealing with minor losses of energy but HUGE gains because of the pump's pressure gain caused by momentum.
There could have been made a way for you to pump the recycled water to the remaining height in order for it to go back to its water source.
Then you would really have a convincing free energy machine!
If you could just have converted a small amount of momentum from the pump output to drive some primitive waterwheel or anything, then you could have completely transferred all the water from a lower potential to a higher one.
And you know, if you did this then you could send all of the water in a loop, then at the same time push some kind of generator or secondary water pump.
Then you could have irrigated those dry lands from a river far away ; )
Again this is really interesting, and the important part is that you are using momentum as a form of pneumatic gear which by itself will increase the potential energy.
In reality all gears can do this, because of potential difference and because velocity in a kinetic energy equation increases the energy by its square, making it superior to mass.
E = V'2 * M * 1/2
See what a simple gear can do?
All the best : )
Static energy...
Dynamic energy...
Two forms of the same.
Nabo00o
Again to all watching this, I cannot stress enough how incredible a gear or a simple machine as they are called really is, especially a pneumatic/hydraulic one (they're almost without loss).
I have verified this for my self theoretically now, with simple weights hanging down and connected to a gear, which then is further connected to weights of different masses. You will as a matter of fact generate more energy the more the leverage makes the second weight move.
Because distance versus force is inversely proportional in their relationship, while mass versus velocity is not, you can effectively create the double amount of energy if you decrease the force by 0.5 and increase the distance by 2.
A doubling of distance will cause the the velocity to double, but the kinetic energy stored in a moving body is affected four times more by the velocity than by the mass, this is also why doubling the speed of a car requires four times as long time to brake than before (if you used the same force on the brake pedal) because the energy stored in car is four times as much.
This does also apply to water in motion, so this is much more a realization of the actual workings of nature than something anyone can get a patent on. After all, the leverage is an ancient device.
Wish you all a good day  ;)
Static energy...
Dynamic energy...
Merg
The latest news from Freeenergynews.com:
Milkovic Output/Input Measured at 1.46 - Ronald Pugh, a Canadian machinist, reports on the pendulum-lever system efficiency measurement he conducted. Once again, he confirms the super efficiency of Milkovic's Two-stage Mechanical Oscillator.
http://www.veljkomilkovic.com/Images/Merenja/Ronald_Pugh_Input-Output_Measurement_Mk5.pdf
Finally, that is something we have been waiting a long time.
Cloxxki
Hurray!
Then it should take but a few hours worth of fiddling to close the loop!
I've proposed simple setups for this, surely others have proposed even better ones.
So, what's taking the inventor and the replicators? 12:1, that's offers room for some friction losses, I'd say?
Nabo00o
Quote from: Merg on May 18, 2009, 10:01:16 AM
Thanks you for the report Merg! Its great to have some independent replications available, this one those also seem to be professionally conducted.
Someone should also try a pneumatic solution to the trigger and power handling, it can probably do just as well (or better) than an electrical one.
Static energy...
Dynamic energy...
