0 Members and 25 Guests are viewing this topic.
i_ron
Quote from: fritz on May 19, 2009, 08:34:49 AM
If started from pendulum....
If I mess around with the counterweight initially - I can make the pendulum swing even from the output. (but this is probably lots of _work_)
There is no mechanical "diode" or ratchet which decouples both oscillations.
If the stuff works on it´s own - you can´t say that one part drives the other.
Its one piece.
You are correct to a point but note in my long post that you don't even need the counterweight.  So yes, most definitely, the force at the pendulum pivot drives the arm which drives the counter weight/load. I will go into this more once people are up to speed here.
Ron
hansvonlieven
Quote from: Cherryman on May 19, 2009, 10:14:47 AM
When I see him driving a pump (resistance)  would it then not be very easy to create something like the attached drawing?
I'm sure i'm overlooking something... because it can not be that simple....
You cannot use a crankshaft in the Milkovic device. Because the device is in many ways a double pendulum it has the same chaotic tendencies, unless severely dampened. Even then every second stroke length is different. A crankshaft requires a uniform stroke length in order to function.
Hans von Lieven
Nabo00o
Quote from: hansvonlieven on May 19, 2009, 05:18:37 PM
Hans von Lieven
True, but you could use a double ratchet system like Tommy Lee Reed did, it converted 100% of the linear force directly into torque, practically without loss.
Combined with this setup the pendulum would be very efficient at driving a wheel.
Static energy...
Dynamic energy...
Two forms of the same.
hansvonlieven
Quote from: Nabo00o on May 19, 2009, 05:25:44 PM
I proposed this in 2007,complete with my tongue in cheek animation of a "Milkovic Perpetuum Mobile".
See http://keelytech.com/news/milkovic.html
Hans von Lieven
Cherryman
Or the driving mechanism of this attached :
