Pierre's 170W in 1600W out Looped Very impressive Build continued & moderated
Started by gotoluc, March 23, 2018, 10:12:45 AM
FixedSys
Quote from: listener192 on June 14, 2018, 03:48:20 PM
Doesn't look like attraction to me.
Anyhow I took the PM's out of my rotor as they caused distortion to the waveform.
L192
I don't see attraction either. Just see that it's wound as wide as possible and as snug as possible.
forest
listener192
Quote from: listener192 on May 31, 2018, 05:07:12 AM
I did not see this.
Although 10A pulses were being returned to the cap bank via the recovery diodes, most of the current to drive the relays was coming from the line supply. So the resistor stayed cold throughout operation. The voltage on the cap bank did not elevate much above the DC supply on the 400V 150uF cap. I just could not clock the relays fast enough to achieve a higher output.
L192
So actually what I was seeing was not recovery but the 10A pulses were just the lower resistance path through the recovery diodes to recharge the caps from the DC supply, as PmgR explained.
With the half bridges you can see there is very little recovery current back into the cap bank. This is not surprising as no coils really turn off.
Even the last coil that has a current reversal during the progression of the waveform does not develop any  recovery current, contrary to what some have speculated.
The only time you do see recovery current is when all coils are turned off (assuming you allow that in the control code).
L192
listener192
Quote from: r2fpl on May 24, 2018, 03:53:06 PM
It is not easy to repeat the first time because you have to adjust.
You must find the answer that you are missing in what you did. It is not easy to understand immediately. "Think straight and you will find". I agree with these words. It is a cliché but it is. Do not look for mA search A. The diodes have two functions I think that you already know. When the effect appears, they come to life. Everything will be the same.
It's hard to think about it with what you have on the table because there is too much going on there. Even I do not know how to do it right now. You need a lot of work to continue joining the whole.
I apologize for not showing you the video, but if I showed you, you would know what to do. Do not take offense at me.
It's good that you write about what you do. Maybe you will come by yourself and maybe someone will tell you more. Jardee says that maybe a few people already know. Possible. Certainly there are those who do not write and do.
If you do not find it yourself, Pierre has promised us that he will show and say how it works and how to do it. If more people would be interested in this, it would be stated.
Lenz, I do not think so.
So by now you should be able to show some O.U. results, without showing the specific setup, hence keeping the secret you have discovered.
L192
