Pierre's 170W in 1600W out Looped Very impressive Build continued & moderated
Started by gotoluc, March 23, 2018, 10:12:45 AM
pmgr
Konehead,
The way Pierre had his poles/coils configured and biased is as follows:
6 poles each consisting of 6 coils in series. All poles in series (so 36 coils in series together with coil 36 connecting back to coil 1).
He put +Vdd on coil 1, 13, 25 and GND on coil 7, 19, 31. So this effectively puts each pole N/S (consisting of 6 coils in series) in parrallel with the other poles.
This leads to the 6 poles N S N S N S (or nnnnnn ssssss nnnnnn ssssss nnnnnn ssssss) where capital N/S represents a pole and small n/s are the individual coils)
PmgR
cheors
Pierre montre le champ magnétique avec de la limaiile de fer.
Je me demande pourquoi les particules de poudre de fer tournent à la fois sur elle-mêmes (à la vitesse de commutation des relais: quelques hertz) et très lentement autour du stator en plusieurs dizaines de secondes.
Il semblerait qu'il y a 2 champs très différents !
Pouvez-vous expliquer ce comportement ?
Pierre shows the magnetic field with iron limaiile.
I wonder why the particles of iron powder turn both on themselves (at the switching speed of the relays: a few hertz) and very slowly around the stator in several tens of seconds.
It seems that there are 2 very different fields!
Can you explain this behavior?
listener192
[quote author = cheors link = topic = # 17653.msg522769 msg522769 date = 1529511237]
Peter shows the magnetic field with iron limaiile.
I wonder why the iron powder particles rotate at the time on her own (the relay switching speed: a few hertz) and very slowly around the stator by several tens of seconds.
I wonder why the particles of iron powder Both turn it Themselves (at the switching speed of the relays: a few hertz) and very slowly around the stator in Several tens of seconds.
It Seems That There are 2 very different fields!
[/quote]
Well my thought is the waveform switching speed is only 16ms however,  waveform amplitude varies from 0 to 100% at 60Hz.
L192
cheors
Pour moi, cela n'explique pas le déplacement lent des particules autour du stator.
For me it doesn't explain the slow particles displacement around the stator.
seaad
