Pierre's 170W in 1600W out Looped Very impressive Build continued & moderated
Started by gotoluc, March 23, 2018, 10:12:45 AM
Ufopolitics
Hello again...
There is a way to feed coils (by a different circuit) and reverse their polarity, without reversing from positive to negative on the switching circuit side.
By having a High side (+) and a Low side (-) Channels, independently or isolated from each others...this way, by simple fast switching diodes we can derive the BEMF or Radiant Energy away from the switching circuit from each Channel.
But this is another material, which I will disclose when I open a new thread...because this design will not only work for static rotor generators, but also for motors.
It will be on the Revival of MAEM, My Asymmetric Electrodynamic Machines... ;)
Cheers
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
Ufopolitics
Hello to All,
Ok, first I want to post here a video about someone out there replicating Pierre Cotnoir DZ Gen (no big deal)...It was uploaded originally by Member Lota at the Holcomb Main Thread, then deleted by being not related to HES Tech (in my opinion, it is about the same exact principle), Member Ramset (Chet) also asked me to post it here...no problem man!!...it was on the wrong Thread...So, it belongs here now...You guys are right.
Neues Projekt DZ-Generator
Second, I am developing a way to make this same setup to work based on simple FET's circuit in Cascade arrangement (no processor, no timer, no sequential chip required)...so you guys could add as many FET's per shifting Phase as you like...better than relays, more reliable, faster switching plus rated at higher amps and volts...harder to blow if heatsinked properly (FET's would never get on fire like a relay with a plastic casing).
Ufopolitics
―Leonardo da Vinci
kolbacict
Quote from: Ufopolitics on September 08, 2022, 10:45:51 AM
Your MOSFET are not made in plastic cases?
Ufopolitics
Quote from: kolbacict on September 08, 2022, 01:34:37 PM
FETs body is NOT a soft plastic, thin walls like a relay is...it is close to a Mica Material, which can stand very high temperatures.
A Relay is built within a plastic BOX, with Oxygen inside...FET's body is vacuum proof, made where all contacts are...
Pierre Cotnoir relays got on fire...they are not designed for this job.
But if you want, you could build it with russian relays left from the old USSR...hahahaha
Ufopolitics
―Leonardo da Vinci
kolbacict
And what about hermetic contacts without oxygen in sealed in glass?
