Pierre's 170W in 1600W out Looped Very impressive Build continued & moderated
Started by gotoluc, March 23, 2018, 10:12:45 AM
seaad
r2fpl
I found problem L298n.
When connect 2 channel (ex. coil1 and coil2) Voltage is different beetwen them.
I change L298n to another new. I changed coil 1-2, 2-1. Still channel 1 is more voltage to 2 channel less voltage !
1 = 0.56 ohm
2 = 0.56 ohm
When driver no load, voltage is equal.
Solution:
join 2 channel together and make one L298n for 1 coil
calibrate voltage used PWM. this method takes 2 pin arduino more. Total 6 pins on 2 channel.
https://youtu.be/_jbd0DPaQg0
I think this driver is very poor for our applications.
temp 80C about 5 minutes work.
r2fpl
I redraw H bridge for Arduino.
Maybe replaced this mosfets to multi mosfet ? I write few post later.
r2fpl
L298n - test 2 channel witch 1 coil
There is still a difference on the channels although it is the same coil.
https://youtu.be/hvrPy_lQfDI
r2fpl
L298n - and another problem.
Overheating 85C ! destability output. We needs better cooling for this driver.
https://youtu.be/TgLBk3GdHSA
