OzzoG Pune Machine
Started by burnit0017, March 31, 2018, 09:32:11 AM
burnit0017
https://youtu.be/JRGnZWhG3lw
The warmer weather has almost returned and it is time to build and test another device. Over the winter I completed a large pulse engine.
https://youtu.be/UUZhyh39yP4
I also completed a hand crank PMA with Cap dump circuit using a PWM, it works will for charging a superCap bank.
It looks like the OzzoG device uses mechanical advantage and gravity. I can use a one bearing on the output side. The pulse motor with step down gearbox will drive the input. I will use a cam to turn on the PMA as the weight falls at the output.
I will post results  when available.  Has anyone tested a similar device? Comments welcome.
burnit0017
https://youtu.be/7xxQZk1bxZU
here is another possibility, pulse at the input is required
